Old March 5th, 2020, 06:44 PM   #1
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
Sourcing 2 Gaskets inside Gas Cap?
My gas cap has been leaking to the point where it's been spilling /venting fuel and robbing me precious mpg. I temporarily fixed this by disassembling and cleaning the fuel cap, used gasket sealant on the inner square gasket (which had shrunk partially deformed) and sprayed silicone spray lube
everywhere, including the ring gasket that seals to the fuel tank . This helped reseal my tank and I gained 40 miles extra on my next tank fillup and since then I can get 40-ish mpg in the city vs the 32 mpg I've been getting prior
Trouble is the gaskets are deteriorating and would like a more permanent solution. I looked on bikebandit.com and the gaskets aren't sold individually.
Service Manual Says to Replace Gasket, but they aren't sold individually:
Hard To See Here, But Circle Gasket is Starting to Crack On Backside and Edges:
Under the Circle Gasket, The Square-ish Metal Section Shown Has a Square-ish gasket underneath it that is deformed and I temporarily resealed this using gasket sealant:
Anyone have a source for those gaskets? I'd rather not buy a whole new gas cap if possible. Looking on eBay used gas caps came as a set with ignition and rear seat locks and we're $80+.
Last futzed with by nocturncal; March 6th, 2020 at 12:27 AM.
Old March 8th, 2020, 01:17 PM   #2
arnvc
Motorcycle(s): ex250
gasket
for my gasket headaches I end up at , Real Seal CO , 1971 Don Lee Pl , Escondido ca 92029, 760 743 7263. not sure if they have a catalog. walking in ,they measure dia, ask aboot applications, heat cycles, temps , fuel/oil, high/low psi . must be other supply houses around. good luck
arnvc is offline   Reply With Quote
Old March 8th, 2020, 01:19 PM   #3
Old bicycle inner-tubes are your friends!!!
Gas Tank Lock stuck? Maintenance for gas cap with pics! Skippii 1986 - 2007 Ninja 250R Tech Talk 35 May 6th, 2021 09:03 PM
Gas coming out on SSR threaded keyless gas cap. Topaz 2013 - 2017 Ninja 300 Tech Talk 15 September 25th, 2018 01:01 PM
