Old April 18th, 2017, 04:31 PM   #1
daverdfw
Motorcycle(s): 2009 Ninja 250
Is pregen petcock operated only on a vacuum like the newgen?
I have a pregen I am working on, and it has been sitting for several years. Trying to clean out the tank and petcock, when I turn it to the ON position nothing comes out. Also it has 2 sections for a hose, any idea where the second line is supposed to run to? Thanks!
daverdfw is offline   Reply With Quote
Old April 18th, 2017, 04:35 PM   #2
Pregen Petcock:
ON = needs vacuum for flow
OFF = OFF
RES = reserve, needs vacuum for flow
One barb is for fuel output
Other (smaller) barb is for vacuum from carb
Old April 18th, 2017, 04:36 PM   #3
daverdfw
awesome thanks! Thats what I thought! I will check the service manual for the routing of the hoses.
Old April 18th, 2017, 04:39 PM   #4
Snake
Snake's Avatar
Yes the petcock only allows fuel to flow on a vacuum.
Old April 18th, 2017, 04:52 PM   #5
daverdfw
Originally Posted by Triple Jim View Post
Pregen Petcock:
OFF = OFF
hmm Ok I need to see where from the carb is runs from.
Old April 19th, 2017, 07:05 AM   #6
Petcock pix -http://faq.ninja250.org/wiki/Rebuilding_the_petcock/fuel_tap
http://faq.ninja250.org/images/0/03/832902.jpg
Vacuum-Less Petcock ninjunk 1986 - 2007 Ninja 250R Tech Talk 14 August 24th, 2023 11:30 AM
Guess I Had a Vacuum Leak in the Petcock VaFish 1986 - 2007 Ninja 250R Tech Talk 18 November 16th, 2015 01:55 PM
88-07 Gas Cap Gasket, Petcock, Vacuum Slides shiftdrift06 Items Wanted 2 December 4th, 2014 02:38 PM
Removing the vacuum spring from the petcock. berserk81 General Motorcycling Discussion 5 November 5th, 2013 08:07 PM
Vacuum nipple came off petcock - fix or replace petcock? fierostetz 1986 - 2007 Ninja 250R Tech Talk 3 November 24th, 2012 11:03 AM
