Old April 10th, 2012, 08:22 PM   #1
b4idie
b4idie's Avatar
Motorcycle(s): Ninja 250r and 08 zx10r
HELP PLEASE!!! Proton's now flashing on both sides
I installed protons the other day along with a integrated blinker tail light with the electrical relay ep34 and everything worked perfectly. today, I just received hotbodies undertail and decided to put that on. As I was nearing the end of the install, I tried the blinkers and to my surprise the blinkers were blinking on all sides like a hazard light. So I disconnected the rear LEDs completely and tried it again and now both protons blink together any way I place the switch. Please helppppppp!!
PROBLEM SOLVED THANK YOU!!!
Last futzed with by b4idie; April 11th, 2012 at 03:03 PM. Reason: solved
b4idie is offline   Reply With Quote
Old April 10th, 2012, 09:39 PM   #2
NathanUc
B-Town Ninja
NathanUc's Avatar
Motorcycle(s): Black 2013 Ninja ZX6R ABS
Make sure your grounding cable (from the EP34) is firmly attached to the frame. I had a similar issue when the grounding wire was slightly loose and caused my signals not to flash.
It might be related, it might not. I'm not really sure but it's something quick/easy to check.
Downgraded to a 2013 636. Previous owner of a 2010 250r
My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja
NathanUc is offline   Reply With Quote
Old April 11th, 2012, 02:30 AM   #3
dma
dma's Avatar
Motorcycle(s): 09 Ninja 250
http://www.ninjette.org/forums/showp...17&postcount=1
dma is offline   Reply With Quote
ECU Flashing garth285 2013 - 2017 Ninja 300 Tech Talk 30 July 13th, 2015 11:47 AM
Dashboard flashing? arnoldc6 2008 - 2012 Ninja 250R Tech Talk 4 March 27th, 2013 05:55 AM
Help needed: Weird flashing rate chokne 2008 - 2012 Ninja 250R Farkles 8 June 28th, 2010 05:31 PM
Higher flashing rate on new turn signals??? Kitdog 2008 - 2012 Ninja 250R Farkles 10 June 25th, 2010 12:17 PM
Faster flashing signal randomwalk101 2008 - 2012 Ninja 250R Tech Talk 9 January 23rd, 2010 11:56 PM
