#1 |
Biker Noob
Join Date: Apr 2014 Motorcycle(s): 2004 Honda Shadow 750 Aero Posts: 176
How to install Yoshimura Fender Eliminator
So I am going to install the Yoshimura Fender Eliminator however I was hoping someone could explain the part about drilling the rivets in the stock blinkers or atleast have a pic showing what needs done.
Riding as I stole it. |
#2 |
Join Date: Aug 2012 Motorcycle(s): '11 250R SE (FI), '14 Daytona 675, '14 Sprint 1050 GT SE Posts: 121
Hi,
I don't remember exactly what I had to do from when I installed this kit but it was fairly obvious when I came to it. Something like the way the indicator is mounted to the stock tail, and you need to separate it hence drilling the rivet is necessary. I don't remember it being troublesome. HTH, Pete |
#3 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
Once the rear fender is removed you'll be able to see the rivets holding the blinker mounts to the fender, just drill those out and the brackets will come off allowing you to mount them to the new yoshi fender kit. Great kit and well worth the money.
#4 | |
Biker Noob
I think I have the blinkers installed in correctly. Here is a pic. Can someone explain how to install them.
#5 |
Each blinker needs the rubber grommet that fits onto the bracket with the supplied washer behind it.
Yoshimura fender eliminator install question | joecool | 2008 - 2012 Ninja 250R Tech Talk | 7 | August 13th, 2014 08:20 PM |
Yoshimura Fender Eliminator | cstro250r | Pictures | 42 | June 14th, 2014 05:17 AM |
Yoshimura fender eliminator | SpicyNuggets | 2008 - 2012 Ninja 250R Tech Talk | 4 | January 20th, 2013 08:37 PM |
Help!! install fender eliminator | uncle hilty | 2008 - 2012 Ninja 250R Farkles | 7 | October 9th, 2012 09:43 AM |
Anyone have the Yoshimura fender eliminator kit? Reviews? | Little_Ghost | 2008 - 2012 Ninja 250R Farkles | 9 | February 7th, 2012 06:24 PM |
