Old May 4th, 2012, 05:49 PM   #1
ubnewbie
ubnewbie's Avatar
Motorcycle(s): none yet
Question Rear sets Question
Hi I'm a taller rider and I'm wondering if it would be a good idea to have rear sets installed
Do they raise your knee or do they sweep you feet back
I realize that rear sets are for a sportier stance and to raise the foot pegs for better ground Clearance
I don't have the 250 yet , And was wondering if anyone regrets installing them
"Motorcycling is not, of itself, inherently dangerous. It is, however, extremely unforgiving of inattention, ignorance, incompetence, or stupidity."
ubnewbie is offline   Reply With Quote
Old May 4th, 2012, 10:51 PM   #2
/moved to farkles; not protective gear
Old May 4th, 2012, 11:54 PM   #3
They sweep your feet back.
They're a little uncomfortable for longer rides, but I don't regret installing my rearset adjusters.
Old May 5th, 2012, 09:08 AM   #4
edxmon
edxmon's Avatar
Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013)
hmm I was just thinking about rear sets. My legs are long enough so that my knees hit the widest part of the tank. Any way to lower my knees without losing clearance or having my feet way behind my butt?
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips
edxmon is offline   Reply With Quote
Old May 5th, 2012, 10:49 AM   #5
Not really. Lowering the pegs reduces ground clearance. Moving them back puts your feet back, but would likely get your knees a little lower on the tank.
There's a DIY on here for Buell blast pegs. Those lower the pegs a little.
Rearset adjusters move the pegs back and up.
If you did rearset adjusters and used the furthest forward holes to attach the rearsets, then used Buell pegs, you could likely get pegs that are the same height but back a little. That might be your best compromise.
Personally, further back is more comfortable. The rearsets in their stock position feel like a dirt bike to me. My adjusters are set at the lowest and furthest back position possible. If you did that with buell pegs, you could probably get pegs that didn't make you crunch up.
Old May 5th, 2012, 11:44 AM   #6
edxmon
edxmon's Avatar
thank you sire, I'll go look at that DIY right now. If I can lower my knees 1-2 inches the bike will literally feel perfect, right now my legs are spread too wide because my knees are above the tank indentations.
Old May 5th, 2012, 12:28 PM   #7
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
Thought the same, but kinda like that too..
Op -- I scoot my arse back as far as I can, use the ball of foot, and that helps get better knee position for aggressive riding. Still have your knee hit tank to shift.
Just cruising around, my knees have gotten used to being at the widest part of tank. Again scooting but far back helps some, even when not crouching at all.
Old May 5th, 2012, 01:38 PM   #8
edxmon
edxmon's Avatar
I'm sitting on the bike now, and I think I would like the rearsets, but my right foot would almost have to touch the exhaust heat shield. Are there some that go that far back?
Gixxer rear shock question - rear stiffness too high cookiebug79 2008 - 2012 Ninja 250R Tech Talk 20 January 17th, 2015 08:19 AM
WTB Rear sets Ducati999 Items Wanted 1 March 16th, 2014 04:41 PM
the2wheels rear sets Cam0 2008 - 2012 Ninja 250R Farkles 3 July 5th, 2012 06:41 PM
OEM rear sets delcoco_ninja Items Wanted 4 February 21st, 2012 03:54 PM
Rear sets or not loz944 General Motorcycling Discussion 8 January 14th, 2012 08:54 PM
