May 26th, 2014, 08:39 AM | #1 |
Join Date: May 2014 Motorcycle(s): 2006 Kawasaki ninja 250r Posts: 3
Gears not shifting
Greeting,
First off I have a 2006 Kawasaki Ninja 250r. I recently just changed my clutch and brake levers because the other ones were bent from when I previously went down. Before I changed my clutch lever everything was running fine. After though, the gears don't shift anymore. 1st and neutral are fine, but when I try to shift up to second the shifter doesn't go up it stops at neutral. If it does shift up its because when I'm riding I need to play around with the clutch lever at different positions. And it is the same with going to 3rd gear. When I shift down its the same problem. What could be the problem? This is a project bike for me to get used to do my own maintenance so I really don't want to spend that much to take it to the shop. |
May 26th, 2014, 08:45 AM | #2 | |
The problem is not in the transmission, but in the last thing that you touched: the controls for the clutch. The lever coming up from the top of the clutch cover is not being deflected an angle big enough to fully disengage the clutch. Only you, being there and knowing what you changed, can find out how to make it work.
May 26th, 2014, 08:59 AM | #4 |
May 26th, 2014, 10:41 AM | #5 |
Thank you for the help. I will try adjusting around and see if that works.
May 26th, 2014, 11:00 AM | #7 |
I use Mobil 1 synthetic 10-40w motorcycle oil. I don't know if that could be the problem since I rode it that day and it was working fine and then I change the lever that same day and then that is when the problem occurred. I didn't make any other adjustments. I just changed the levers on the handle bars.
May 26th, 2014, 11:12 AM | #8 |
My bike has too many gears:/ | JohnnyBravo | 2013 - 2017 Ninja 300 Tech Talk | 34 | January 23rd, 2014 09:14 AM |
Grinded gears??? | Kevin2109 | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 24th, 2011 04:26 PM |
What's up with my bike? Dropping gears | Trailerboy531 | 2008 - 2012 Ninja 250R Tech Talk | 15 | June 25th, 2011 12:06 PM |
[topix.net] - Shifting gears: M&M Motor Mall redirects focus to used car sales, servi | Ninjette Newsbot | Motorcycling News | 0 | January 9th, 2011 02:10 PM |
trouble shifting between 2-6 gears | CThunder-blue | 2008 - 2012 Ninja 250R Tech Talk | 4 | December 3rd, 2010 06:21 PM |
