Old June 12th, 2014, 07:38 PM   #1
burnrich
burnrich's Avatar
Motorcycle(s): gpx 250
07 Ex250 USB 2.0 Dual Plug Installation
Hi All,
I've mounted a Garmin bracket (Givi Brand) on the throttle side of the bars and it has enough room to hold the GPS + Mobile phone so I've purchased a dual USB plug with wiring harness and fuse from <http://www.ebay.com.au/itm/Dual-USB-Charger-Flush-Socket-Boat-Marine-Sailing-Motorcycles-N98B-/380898721385?pt=AU_Car_Parts_Accessories&hash=item58af553e69>. The next mission is to mount the SOB somewhere close to the battery but haven't figured out where to mount it yet and was hoping somebody else had already devised a solution to this problem. Ill post some pictures later on but if somebody has any ideas or a better solution than the flush mount USB socket I've purchased already I'd love to hear from you!
Cheers,
Peter.
"Revenge is so very, very sweet"
burnrich is offline   Reply With Quote
Old June 12th, 2014, 09:38 PM   #2
Milsparro
Motorcycle(s): '87 KLR650, '97 Virago
I put my lighter socket in the bottom left wall of the document tray, the body of the adapter goes under the frame tube. If I had a second go at it I'd put it that extra 1/8 of an inch further down.
Milsparro is offline   Reply With Quote
Old June 16th, 2014, 01:53 AM   #3
burnrich
burnrich's Avatar
Solved
Yep thats the way I did it. Thanks for the idea. I stuffed up and got accidently got positive and negative after I did the loom and killed the plug. Ive ordered two more off ebay. Should got the fluke out but couldnt be bothered. Took three weeks to deliver and three seconds to blow the ass out of it!
[webbikeworld.com] - BurnsMoto Dual-Port USB Chargers Review Ninjette Newsbot Motorcycling News 0 July 6th, 2014 01:10 PM
Battery Tender Quick Disconnect Plug with USB Charger Kgreen 2008 - 2012 Ninja 250R Tech Talk 4 March 27th, 2014 10:25 PM
Need Electrical Help - Dual USB & Cigarette Outlet conrya5 2008 - 2012 Ninja 250R Farkles 35 January 28th, 2014 02:52 PM
[webbikeworld.com] - Dual Horn Relay Wiring Harness Installation Redux Ninjette Newsbot Motorcycling News 0 July 13th, 2013 07:40 PM
[webbikeworld.com] - BMW Scooter Dual Horn Installation Ninjette Newsbot Motorcycling News 0 December 20th, 2012 04:40 PM
