Old August 14th, 2012, 09:26 PM   #1
elpato
Motorcycle(s): 2005 EX250
what goes on the tube between the carbs?
Sorry to start a new thread for this, but I wanted everyone to see it. So I have the carbs apart for the second time. I notice that between the two carbs there appears to be a plastic tube that is not capped. Wondering if that needs to be plugged or where it goes? Thanks for any help or a link to some pictures or something.
Elpato
elpato is offline   Reply With Quote
Old August 14th, 2012, 09:34 PM   #2
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
I've never had the ninja carbs on the table before, but from my experience with carbs in general (since I have an old bike, it's a LOT), I'm going to have to say that it's a vent tube and is supposed to vent to atmosphere.
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old August 14th, 2012, 09:39 PM   #3
elpato
You are right. Sorry everybody I suffer from premature thread starting. I used the search feature again and found some really nice pictures of everything.
Sorry for wasting everybodys time...
Old August 14th, 2012, 09:41 PM   #4
elpato
back out to the garage to continue cleaning. I pulled the air/fuel plugs out and found one almost all the way closed. Still running into the RPM problem. Pulled the air/fuel screws, springs, washers out and see a piece of gunk sitting right over the hole. So I'm back out to do more cleaning like I should have done the first time...
Old August 15th, 2012, 05:46 PM   #5
jschatte
jschatte's Avatar
Motorcycle(s): 1988 Ninja 250
http://www.ninjette.org/forums/showthread.php?t=101819
If i am understanding what your asking correctly it is a vaccum line and it should be hooked up.
jschatte is offline   Reply With Quote
Old August 15th, 2012, 08:48 PM   #6
elpato
no it is not one of those hoses. It is at the very top between the two carbs. It is listed as a fuel overflow tube and is supposed to have a hose attached. Mine does not, but is not a big deal. Thanks for the feedback.
Old August 17th, 2012, 05:12 AM   #7
Jim Moore
Jim Moore's Avatar
Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150
It is a little bit of a big deal. You don't want gas dripping down onto a hot exhaust. I recommend you buy a couple feet of 1/4" fuel line and a barbed connector and run that line down below the exhaust on the right side. There's a metal hoop on the frame you can run it to.
Jim Moore
Jax, FL
Jim Moore is offline   Reply With Quote
coolant tube joshuafrench 1986 - 2007 Ninja 250R Tech Talk 6 December 23rd, 2013 01:57 AM
[topix.net] - From Twin-Tube Single Shocks to Single-Tube Twin Shocks: Ohlins... Ninjette Newsbot Motorcycling News 0 June 5th, 2012 04:30 AM
[sportrider - latest stories] - From Twin-Tube Single Shocks to Single-Tube Twin Shoc Ninjette Newsbot Motorcycling News 0 June 4th, 2012 06:40 PM
Mystery Tube HorizonXP 2008 - 2012 Ninja 250R Tech Talk 3 August 28th, 2010 05:54 AM
What is this? (vent tube) edbro 2008 - 2012 Ninja 250R Tech Talk 7 December 28th, 2009 10:55 AM
