October 23rd, 2012, 03:43 PM | #1 |
Join Date: Oct 2012 Motorcycle(s): 2013 Ninja 300 Posts: 121
Noob question: License plate light
I bought 92 Ninja 250 and am having trouble figuring out how to get he old license plate off....
I feel like an idiot but I cant figure out how to get the license plate light disconnected, can anyone instruct me on how to do this? I have been searching online and have found nothing. |
October 23rd, 2012, 03:49 PM | #2 | |
MOTM - Mar '13, Jun '14
http://www.ninjette.org/forums/showthread.php?t=68633
October 23rd, 2012, 03:55 PM | #3 |
I saw that thread already actually but that is just some options for new lights. The one on my bike works I just don't know how to get it off.
Its a light sort of like this just screwed into the top left of the license plate. |
October 24th, 2012, 01:18 PM | #4 |
Was able to figure it out, and got the license plate okay
Now I just have to figure out how to fix the horn and get it inspected and I should be good to go. Any tips on what could cause the horn not to sound? |
October 24th, 2012, 01:54 PM | #5 |
Join Date: Mar 2011 Motorcycle(s): 96 Ninja 250EX , 87 CBR 1000, 86 TRX 260R, 86 KXT 250, 84 ATC 200X, 82 ATC 250R (w/CR480) Posts: 134
Ok as far as the horn not sounding... EAsy to track down basically the issue could be one of four things
1. Horn inop 2. Fuse blown 3. Bad switch 4. Bad wiring First check fuse to ensure its good... Then work your way back from the horn you will need a test light or multimeter .. Key on lights on test for voltage at horn when you push horn button and work from there |
October 24th, 2012, 02:54 PM | #6 |
Hmm thanks, I have a multimeter so I can test the wiring.
Which fuse would be for the horn? I have a 92 bike which I think has an older fuse box than most. It looks like this (with 4 10 amp fuses in there plus the two spares the one in the picture is missing one fuse) I am not sure which would be for the horn or if there even is one? The fuses are listed as Front, Back (headlights I assume), ATT and the last one was fan I believe I will have to double check that. |
October 24th, 2012, 04:15 PM | #7 |
October 24th, 2012, 04:25 PM | #8 |
Yeah I found that but mine has a different type of fuse box than that unfortunately.
October 24th, 2012, 04:28 PM | #9 |
Then let the bike idle with everything on. Then start pulling one fuse at a time to see what turns off with each fuse. Should be easy enough. You just might annoy your neighbors from testing the horn
October 24th, 2012, 06:52 PM | #10 |
Not sure as to which fuse does what maybe check out the above link to help ya there.. But even easier make sure all sockets have a fuse in them then check for continuity on each fuse with your meter . If there all good then you can eliminate the possibility of a bad fuse
October 24th, 2012, 07:04 PM | #11 | |
Tomorrow I will test the wires with a multi meter. If I am getting a current when I press the button does that just mean the horn is probably bad? |
October 24th, 2012, 07:06 PM | #12 |
likely. Replace it and see. Horns are cheap
November 3rd, 2012, 12:45 PM | #13 |
Looks like I need a new battery as well now. Can anyone recommend a good one I can buy locally for a reasonable price? How much should I be expecting to spend on a new battery?
November 4th, 2012, 11:53 AM | #14 |
Sorry for all the questions but I am still having trouble with the horn, I tested it with a multimeter but I am not sure if I am doing it right.
I set it to 20Vdc and grounded one end to the foot rest and put the other end on positive end of the horn (I just rested it against the metal piece the wire is attached to). I got a reading of 11.5V on the meter without pushing the button and when I pressed it nothing happened. Does that sound correct? If so I am guessing this means I need to try the switch next? |
so how do i replace my license plate light...? | gitoy | 1986 - 2007 Ninja 250R Tech Talk | 2 | August 5th, 2014 10:07 PM |
Free OEM Blinkers, Tail Light, and License Plate light | Floki | Free stuff! | 15 | March 12th, 2014 08:15 AM |
FS: pregen license plate light oem connector | GlassAnkles | Motorcycle-related | 0 | January 14th, 2014 10:56 AM |
License plate/tail light | cbinker | 2008 - 2012 Ninja 250R Farkles | 2 | May 19th, 2013 11:13 PM |
temporary license plate question | bikermunda | 2008 - 2012 Ninja 250R Tech Talk | 22 | February 19th, 2009 08:37 AM |
