Old July 7th, 2010, 07:15 AM   #1
randomwalk101
self wrencher
randomwalk101's Avatar
New gen suspension upgrade
What are you guys running? What's best route to go?
Front:
- racetech sprints / oil / gold valve emulator?
- AK20?
Rear:
-penski
-ohlins?
Last futzed with by randomwalk101; July 7th, 2010 at 08:33 AM.
Old July 7th, 2010, 10:41 AM   #2
almost40
ninjette.org Monkey Spank
almost40's Avatar
I dont have a problem with the stock stuff (im short n skinny) but weight has alot to do with it...how heavy are ya??
Black 250R
Full Area P QC
Old July 7th, 2010, 10:53 AM   #3
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
Race Tech .85 with Sling shot pre load adjusters 15w fork oil.
I don't waste time with the emulators but others do. The intimidators are good.
Jean you know you want my shock.
Guys have had issues with ohlins but the fastest guys are on them. Penske gets my vote until the new shock company that cannot be mentioned comes out with theirs.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old July 7th, 2010, 11:20 AM   #4
randomwalk101
self wrencher
i'm at 170...yeah I gained 20 lbs in a year I'm fat now
for street stock suspension is okay...I'm thinking about the track though.
Old July 7th, 2010, 11:29 AM   #5
ztrack157
The Sportisi Master
ztrack157's Avatar
My 170lb guys are running .80 racetechs
Old July 7th, 2010, 03:23 PM   #6
randomwalk101
self wrencher
170 lbs but trying hard to go back down to 155. I'm 5,9" but I guess height doesn't matter in suspension.
Posted via Mobile Device
Old July 9th, 2010, 11:25 AM   #7
08ninja250
08ninja250's Avatar
Motorcycle(s): 2008 ninja 250
im 130lbs, 5'8" and Racing my bike. what fork oil and suspension upgrades would you recommend?
08ninja250 is offline   Reply With Quote
Old July 9th, 2010, 11:40 AM   #8
2WheelGuy
2WheelGuy's Avatar
I'd start with .70 springs, 15w oil and BT-003 tires.
After some time on the track can do more as your speeds increase.
AFM #278
Old July 9th, 2010, 05:57 PM   #9
08ninja250
08ninja250's Avatar
Ive been doing some quick laps at calabogie. through 18 im bottoming out my fromt suspension and its chattering. and im running a bridgestone bt? on the front and a metzler on the rear.
Old July 9th, 2010, 06:24 PM   #10
2WheelGuy
2WheelGuy's Avatar
Step 1: Get good tires
AFM #278
Old July 9th, 2010, 06:34 PM   #11
08ninja250
08ninja250's Avatar
My tires are good! brand new! plenty of grip
Old July 9th, 2010, 08:26 PM   #12
mikecronis
Motorcycle(s): 2008 Kawasaki Ninja 250R-J, 2005 Honda Superhawk VTR1000
I installed the BT-003 RS tires. They super-rock.
mikecronis is offline   Reply With Quote
Old July 15th, 2010, 09:47 PM   #13
NorCal_250R
Motorcycle(s): 06 Ninja 650R, 08 Ninja 250R, 00 Aprilia SR50 (dead)
What's a slingshot preload adjuster?
NorCal_250R is offline   Reply With Quote
Old July 15th, 2010, 09:55 PM   #14
NorCal_250R
Okay, those Slingshot products look great. Glad someone finally made a KLEEN block-off plate too...
How do those Preload adjusters install if our fork caps are held in with c-clips?
Old July 15th, 2010, 09:57 PM   #15
randomwalk101
self wrencher
Just bought a pair of Intiminator and going with 5w oil + stock spring as a starting point and go from there...(5w was recommended by Intiminator).
Thinking about SS preload adjuster but it doesn't fit stock handlebar. (had to go to 15mm-20mm preload)...might be too much?? any comment?
Old July 15th, 2010, 10:12 PM   #16
randomwalk101
self wrencher
There is a diy on the tech area that tells you what/how to do it
Old July 15th, 2010, 10:15 PM   #17
ztrack157
The Sportisi Master
ztrack157's Avatar
Jordan yes they are held in with c clips. I just put a set on Bartlow's bike.
Old July 15th, 2010, 10:17 PM   #18
ztrack157
The Sportisi Master
ztrack157's Avatar
It's funny. I suggested an emissions block off plate like a month ago to them. Looks like Jim listens.
Old October 16th, 2010, 09:25 PM   #19
08ninja250
08ninja250's Avatar
Whats an intimidator? and emissions block off plate?
Colin #191 - Area P, Elka Shock, Woodcraft Clip-Ons and Rearsets, Attack Race Bodywork, BT 003RS, .700 Fork Springs, DynoJet Stage 2 and BMC High Flow Air Filter.
613 MOTORSPORTS.COM
Old October 16th, 2010, 09:28 PM   #20
08ninja250
08ninja250's Avatar
oh and emulators?
613 MOTORSPORTS.COM
Old October 16th, 2010, 09:42 PM   #21
NorCal_250R
Block off plates are for helping with the
Emissions air injection removal. You only need one.
Intimators are a drop in front suspension upgrade that proves front fork feel and help prevents the forks from bottoming out.
Old October 16th, 2010, 10:15 PM   #22
ztrack157
The Sportisi Master
ztrack157's Avatar
Talked to spears and it sounds like ricor put the intimidators on the backburner. Colin unless your fast I wouldn't put emulators in the bike just yet.
Old October 17th, 2010, 07:46 PM   #23
KTRacing38
2010 250 Cup Champion
KTRacing38's Avatar
Motorcycle(s): 2008 Ninja 250R and 2007 Honda CR150F
I put the Elka rear shock on my bike along with .65 springs in the front and 15w oil. I'm light (~130), but am an experienced racer so for me, this combo works great.
KTRacing38 is offline   Reply With Quote
Old October 18th, 2010, 09:42 PM   #24
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
what rear spring rate do you run on the elka?
Rexbo is offline   Reply With Quote
Suspension upgrade jgcable 1986 - 2007 Ninja 250R Tech Talk 13 February 13th, 2015 02:22 AM
Advice on Suspension Upgrade? Sykes92 2008 - 2012 Ninja 250R Tech Talk 19 May 20th, 2014 12:26 PM
300 rear shock upgrade and front suspension agentbad 1986 - 2007 Ninja 250R Tech Talk 1 January 22nd, 2014 12:07 PM
Front suspension upgrade Rollingmenace 1986 - 2007 Ninja 250R Tech Talk 3 October 4th, 2013 07:42 AM
is this suspension upgrade possible???? brausatch 1986 - 2007 Ninja 250R Tech Talk 5 October 3rd, 2010 03:33 PM
