Old April 10th, 2017, 12:35 AM   #1
Burphel
Burphel's Avatar
Rear axle question...
Ok, a bit of an oddball question here... Last time I changed my rear tire, I accidentally stuck the rear axle in from the right side of the bike instead of the left. And discovered it's a whole lot easier that way. The brake caliper's held in place and you have one less heavy thing to align. The bike came with the axle the other way and all the diagrams in the shop manual show it inserting from the left as well, although it doesn't come right out and say it. Every stock picture of the bike has it inserting from the left.
Does it really matter? I can't think of a reason it would, and I'd love to take advantage of easier tire changes.
(for those of you familiar with the Norwegian phrase "Uff Da", this was one of those moments.)
Old April 10th, 2017, 01:58 AM   #2
I don't think it matters a whit. Whatever is the easiest to get that rear brake mount in place seems like the right way to go. Move to 300 tech area.
Old April 10th, 2017, 03:16 AM   #3
Ram Jet
Ram Jet's Avatar
Thanks
I just bought a 2007 one month ago and both my front and rear axles are inserted from the right. I'll keep it that way since new tires are in my near future. I suppose the only thing to watch out for is swapping the left and right rear spacers. I've never had my wheel off but I saved this photo on my computer;
Old April 15th, 2017, 06:45 AM   #4
Burphel
Burphel's Avatar
From what I'm seeing with a Google search, across models/manufacturers it doesn't matter unless there's an obvious fit issue (or single swingarms, obviously). Manufacturers seem to usually do it so the axle goes in opposite the muffler because that can get in the way of inserting the pin. Even if the muffler's slung low, you can get the nut in there. This isn't an issue for me, so I'll go with holding the damn rear caliper steady.
If you do any type of track riding, taking off and replacing wheels gets to be a fairly common procedure. Less so with Ninjettes than big bikes. But doing your own chain/sprockets and taking wheels in for a tire change saves a fair amount of money.
Old April 15th, 2017, 07:23 AM   #5
jrshooter
Motorcycle(s): ninja 300
i swaped mine for the reasons you stated, no issues.
Old April 15th, 2017, 10:44 AM   #6
Ram Jet
Ram Jet's Avatar
Spacers
I guess on this bike it doesn't matter which spacer goes where. My Honda FT500, on the other hand, will be really screwed-up if you don't get the spacers right - sprocket and disc brake alignment. I did my first tubeless tire change a couple of years ago and I swore I wouldn't do it again. A local shop wants $35.00 per wheel to mount tires. However, I watched a couple of You Tube videos and I may be stupid enough to try it again. I have no problem with tube tires however. One night in the Pocono Mountains I picked-up a 16 penny nail in my rear tire. It went round and round and made more holes in the tube with each revolution. I patched and changed it by the side of the road with the help of my friend's bike headlight and those of the passing cars. Not something I want to experience again.
Cheers,
Bill
Old April 15th, 2017, 05:43 PM   #7
Burphel
Burphel's Avatar
Oh, sorry. I was back to the axle insertion. I'm pretty sure spacers matter for every bike. For exactly the reason you mentioned.
Old April 15th, 2017, 07:11 PM   #8
Ram Jet
Ram Jet's Avatar
Yeah, after I wrote that I was heading to the harware store and it dawned on me you were referencing left or right axle insertion not spacer placement. Sorry.
Bill
Rear Axle Size FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 5 August 27th, 2020 01:12 AM
Rear Axle Torque ZacharyB 1986 - 2007 Ninja 250R Tech Talk 1 April 24th, 2016 07:19 PM
rear axle torque sparkplug896 1986 - 2007 Ninja 250R Tech Talk 10 December 20th, 2013 03:41 AM
Rear axle question Jordan91 2008 - 2012 Ninja 250R Tech Talk 2 December 29th, 2010 02:34 PM
rear axle lube? Buffalony 2008 - 2012 Ninja 250R Tech Talk 8 June 3rd, 2010 09:04 AM
