Old July 24th, 2017, 03:45 PM   #41
Ram Jet
Ram Jet's Avatar
Originally Posted by KikRox View Post
lol exactly ramjet! corn alcohol is for drinking, water is for bathing. all this ethenol trip is about is selling unused crap farmers have laying around to boost profits for fuel manufacturers. it doesnt *do* anything good for non-flex fuel vehicles. its basically just 10% cut. its like going to mc donnalds and getting 10% snouts and entrails in your nuggets because they couldn't get rid of it elsewhere and it allows mc squirts to sell more nuggets. we're getting 10% ****ed at the pump. or 1 dollar out of 10 goes to nothing. or 10% of my tank is filled with CRAP. which is my real issue.
Amen. How did this alcohol get into our gasoline in the first place? The EPA, tree huggers, USDA? If we are now exporters of fossil fuel it's hard to justify trying to stretch a gallon of gasoline by adding alcohol. We can't go back because of the industry we've built around alcohol production. "There's a monster on the loose, it's got our heads into a noose, and it just sits there watching"
Bill
Old July 24th, 2017, 05:33 PM   #42
arnvc
Motorcycle(s): ex250
when my 250 had fuel? problems I'd add some "Ethanol Shield" , haven't had the run on 1 cylinder, refuse to run over an idle problem ever again. you might have to drain the float bowels to clean oot marginal fuel so it will come to life. I get my"e s" at local m/c shop, home depot ,lowes, have it. Am sure auto parts have it also
arnvc is offline   Reply With Quote
Old July 24th, 2017, 05:40 PM   #43
I'm detecting a Canadian accent there.
Old July 24th, 2017, 06:22 PM   #44
KikRox
KikRox's Avatar
Motorcycle(s): 2011 Ninja 250r se
Hoser.
They should give me my own section called kik rox is a silly **** who breaks stuff.
KikRox is offline   Reply With Quote
Old July 24th, 2017, 10:43 PM   #45
MLR
MLR's Avatar
I wish we had E85 more readily available, it is brilliant in boosted applications.
MLR is offline   Reply With Quote
Old July 25th, 2017, 12:41 AM   #46
Ram Jet
Ram Jet's Avatar
E85 is now known as ethanol flex fuel here in the U.S and contains 51% to 83% ethanol. You might as well convert all of your carburetor and petcock "O" rings for use with alcohol, run pure methanol and punch your compression ratio up to 12.5:1 and rejet your carburetor. Your engine will run a-lot cooler. And the price per gallon of pure methanol is only $1.13 (USD)/gallon here.
When you say "boosted" applications are you referring to supercharging? Heck, throw in 5% nitro-methane and let the good time roll.
Bill
Old July 25th, 2017, 01:34 AM   #47
MLR
MLR's Avatar
Bill
By boosted I mean turbo, if E85 was readily available I would drop some coin and get supporting mods and get a flex fuel conversion done on my car where I could run anything from 98 to E70/E85, I could get more power with less boost on E85 and as you stated run cooler.
The lowest I've seen E85 here is 70%.
I believe it's not worth the trouble in running E85 or methanol in my bike as I use it as daily transport, it would be more cost effective to sell the 250 and buy a bigger bike.
Sadly E85 or methanol is not cheap here, but in saying that I care not for the extra cost as the benifits of E85 outweigh the cost.
Old July 25th, 2017, 01:52 AM   #48
Ram Jet
Ram Jet's Avatar
Are you saying you run a mix of 70%/30% ethanol/gasoline in your Ninja? I really don't know squat about gasoline - I only what I've read. All I know is that my bike doesn't run well without it.
Cheers,
Bill
Old July 25th, 2017, 03:13 AM   #49
MLR
MLR's Avatar
Cheers,
Bill
Na mate, ninja is straight 98.
The 70% to 85% is from mates who run E85 in their cars, they run ethanol content sensors which allow the ECU to map for ethanol content and adjust the tune to suit.
Even when the ethanol is on the low side, 70%, they still make a good deal of more power over straight 98.
Only down side is needing to change you oil more frequently.
But again the benifits are worth the slight cost of the shorter maintanance intervals.
My only problem is the lack of suppliers, and carrying jerries and storing drums is not a option for me at this stage.
