April 27th, 2012, 04:15 PM | #1 |
Join Date: Nov 2011 Motorcycle(s): 2005 HON CBR1000RR Repsol, 2012 KAW Ninja 250R Posts: 131
Front caliper behavior when turning left
when I turn the wheel to the left, my front brake lever almost touches the handle bar when I squeeze it. I can see that the entire front caliper is moving as I squeeze the lever. I believe this movement is allowing the pistons to extend more, and that's why the lever moves so much.
this doesn't happen when the wheel is straight or turned to the left. any ideas why this is happening? Last futzed with by samw; April 27th, 2012 at 07:33 PM. |
April 27th, 2012, 06:06 PM | #2 |
Join Date: Apr 2012 Motorcycle(s): 2009 Ninja 250 (blue) Posts: 134
I don't think you should be using the front brake lever when you are turning your handlebars anyway.
Double check your cables and your lever adjustment. Make sure that he cables are routed properly as well. |
April 27th, 2012, 07:35 PM | #3 |
I loosened the caliper mounting bolts and the problem goes away. But when I re-tighten them, the problem comes back. I'll take off the caliper and inspect the pads tomorrow.
April 28th, 2012, 09:14 AM | #4 |
Problem solved. Front axle nut wasn't fully tightened
The caliper movement I noticed was due to the wheel/rotor moving. Glad I checked this before riding |
April 28th, 2012, 12:17 PM | #5 |
April 28th, 2012, 03:25 PM | #6 | |
Join Date: Jan 2012 Motorcycle(s): Green 2012 Ninja 250SE and a Yamaha fino scooter (my wife's really) Posts: 355
Lol but seriously its good that you found that and should be a reminder to all of us to walk around and visually check our bikes and put a spanner on to check things even on a brand new bike. most dealerships give the PDI to the apprentice to do and often things get missed
Be safe ride smart .....a dumb rider is a dead rider |
please help with front caliper | gantt | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 24th, 2015 01:23 PM |
Front caliper bolt size | Vergil | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 16th, 2013 05:35 AM |
WTB: New-Gen Front Caliper | Nemesis | Items Wanted | 1 | December 9th, 2011 07:33 AM |
My front turning signal | TxriderMike | !%@*#$%!)@#&!%@ I crashed! | 21 | September 23rd, 2011 11:44 AM |
Front caliper problem | TS250 | 2008 - 2012 Ninja 250R Tech Talk | 9 | March 27th, 2011 09:04 PM |
