Old July 13th, 2012, 05:08 PM   #1
PistolPete93
PistolPete93's Avatar
Motorcycle(s): 09 Ninja 250r
Need help... like now
So being the adventurer i am, i wanted to change the setting on the flush mount turn signals the previous owner installed. Its the proton flush mount kit. After rearranging the wires, theres 3 total, when I turn one side on, the other signals flashed very dimly. Same thing happens to both sides.
WTFFFF I dont know wth to do or what is going on. And to top it off I killed my battery and cant start my Bike. So now I cant start it.
I know Im a noob please someone save me lol
PistolPete93 is offline   Reply With Quote
Old July 13th, 2012, 05:15 PM   #2
/moved to new-gen tech
Old July 13th, 2012, 05:40 PM   #3
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
If you still have the stock relay, change it to an electronic flasher. LEDs are anal about the right relay. I currently rock the EP34 for a total of 4 flush mount front signals and an integrated LED taillight. Try it. Good luck.
My Videos
EthioKnight is offline   Reply With Quote
Old July 13th, 2012, 05:43 PM   #4
nah, you dont need turn signals.
Old July 13th, 2012, 05:50 PM   #5
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
If you ever have anything usefull to say, instead of smart ass remarks to new members questions, I'd be fraking shocked
Old July 13th, 2012, 06:02 PM   #6
PistolPete93
I dont have the stock relay, It was working fine before I took the fairings off and undid the wiring. I got it to change between the regular blink and strobe (multiple flashes), but when I rewired it, the other side blinks at t he same time, just dimmer.
if it matters at all it also has an integrated tail light on it too
Old July 13th, 2012, 06:34 PM   #7
Lew360
Bueller
Lew360's Avatar
Motorcycle(s): '09 250R
So go back to the original wiring and charge the battery.
Lew360 is offline   Reply With Quote
Old July 13th, 2012, 06:54 PM   #8
PistolPete93
I went back to the original wiring as soon as I noticed the problem
Old July 13th, 2012, 07:13 PM   #9
NDspd
1/4 English, 3/4 Kick Ass
NDspd's Avatar
Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold)
Getting the same feeling here.
NDspd is offline   Reply With Quote
Old July 13th, 2012, 07:50 PM   #10
<3
Old July 14th, 2012, 05:57 PM   #11
PistolPete93
Turn signal problem
When i signal right, the left light blinks too, except very dimly. Same thing happens vice versa. Anyone know what is causing this? This is really bugging me and I need to get it fixed asap
Old July 15th, 2012, 07:01 AM   #12
PistolPete93
Where does the ground wire connect?
Where does the ground wire connect to the body of the bike? I'm having problems with my turn signals and it might be the ground wire. I can't seem to find where it connects to the body of the bike, because the end where it connects to the light is fine
Old July 15th, 2012, 07:10 AM   #13
/merged
Old July 16th, 2012, 06:44 PM   #14
rawbert625
rawbert625's Avatar
Motorcycle(s): the cool ones
Check your frame on the right side, close to the tank. It should have a black/yellow wire leading to it.
http://i.imgur.com/6Y0yf.jpg
Last futzed with by rawbert625; July 16th, 2012 at 06:45 PM. Reason: extra info!
rawbert625 is offline   Reply With Quote
Old July 16th, 2012, 08:17 PM   #15
PistolPete93
Called up proton company, I need a resistor because power is leaking through to the other side, finally found out that is what is going on. Apparently it happens with the leds
Old July 16th, 2012, 08:22 PM   #16
rawbert625
rawbert625's Avatar
Where exactly doe you put the resistor?
anywhere on the turn signal circuit?
Old July 17th, 2012, 09:42 AM   #17
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
I don't get it. Weren't they working before? You shouldn't need resistors then.
broilmebk is offline   Reply With Quote
Old July 17th, 2012, 10:36 AM   #18
PistolPete93
No, because I bought diodes and wired them in, and it didnt work. The reason is becuase when the diode allows flow one way, the other side isnt gettign the flow it needs, so it would only work for one side. I think I'm going with the no cut kit on modmy250
Old July 17th, 2012, 10:38 AM   #19
PistolPete93
No, they were always doing this, I just didnt notice it. The integrated tail light would do the same thing, but i thought it was supposed to do that. When I noticed the front signals doing that, I thought I might have done something, but nope
Old July 17th, 2012, 10:54 AM   #20
broilmebk
broilmebk's Avatar
Ahh okay. Yea, I went with the no-cut diode kit from Tri.
Turn Signal indicator problem! Kevin2109 2008 - 2012 Ninja 250R Tech Talk 12 March 22nd, 2014 09:17 PM
Turn signal problem ChickenRun 2008 - 2012 Ninja 250R Tech Talk 11 June 9th, 2013 05:44 PM
Turn signal problem kawasaki-guy2008 2008 - 2012 Ninja 250R Tech Talk 4 June 4th, 2013 09:07 AM
Turn Signal Problem shawn57187 2008 - 2012 Ninja 250R Tech Talk 3 June 17th, 2011 02:13 PM
Turn signal problem!!! danjaho 2008 - 2012 Ninja 250R Tech Talk 1 March 23rd, 2011 07:25 AM
