Old July 23rd, 2011, 02:30 PM   #1
dirtyrottenninja
Motorcycle(s): ninja 250
problems with intake valves
has anyone had problems with only thier 2 intake valves and or rocker arms breaking or jumping out,or cam damage from the rocker arm jumping out after break and spring retainer shooting off? i cant be the only one with a super noisy valvetrain from only the intake valves on cylinder one, is this a problem contributed to from the chain tensioner always whacking cylinder # 1 hard constantly?maybe wearing the rocker arms or bending the valves or?
dirtyrottenninja is offline   Reply With Quote
Old August 5th, 2011, 03:33 PM   #2
There haven't been many posts of that type of damage here, are you already noticing strange wear?
Old August 7th, 2011, 05:46 PM   #3
greg737
Motorcycle(s): -
I've seen a number of threads about broken rockers over the last 6 years, both here and on the other EX-250 forum. Usually happens after a valve adjustment but not always. And as far as I remember the failures aren't limited to any particular cylinder or intake vs. exhaust.
Apparently it's not hard to end up either stressing the rocker arms or maybe starting a hairline crack in one or more of them, or simply finishing the adjustment improperly with one valve accidentally set too tight.
Of all the parts in the EX-250's valvetrain the rocker arms are definitely the most delicate. This may be intentional to the engine's design. Usually guys post about their bike being "down on power" or "top speed of only 70 or 80" then after a bit of investigation they find a broken rocker (usually only one).
On the good side there's usually no damage. The flow of engine oil washes the pieces of the broken rocker into a quiet corner of the engine head or down the cam chain valley and into the clutch area.
Although I did see one post were the broken rocker had damaged the cam chain. Here's a link to one of the worst, most damaging rocker arm fails I've seen: http://forums.ninja250.org/viewtopic...27e0a84#808531
Good luck with the bike.
should I do intake or just rejet? greenmachine 2008 - 2012 Ninja 250R Tech Talk 13 April 12th, 2015 06:48 PM
How to know you need your valves adjusted? Hero Danny 2008 - 2012 Ninja 250R Tech Talk 42 July 26th, 2014 06:39 PM
Questions on valves. krolinked 2008 - 2012 Ninja 250R Tech Talk 11 February 11th, 2013 04:22 PM
What's wrong with my intake valves? (pics) Skippii 1986 - 2007 Ninja 250R Tech Talk 14 August 11th, 2012 07:47 PM
Which came first...the intake or the exhaust? M-Oorb 2008 - 2012 Ninja 250R Tech Talk 1 December 5th, 2008 01:41 PM
