Old May 11th, 2017, 05:39 AM   #1
sobieski
Motorcycle(s): 250r
Front Sprocket Play
2009 250r with 40,000 miles.
I recently noticed my front sprocket has a good bit of play in first gear.
That is to say:
On a rear stand, engine off, in gear, the front sprocket can turn about 5 degrees, forward or backward before "stopping".
I never noticed this before.
Is this normal, a problem, or a sign of wear?
Thanks.
sobieski is offline   Reply With Quote
Old May 11th, 2017, 06:18 AM   #2
Are you saying the sprocket shaft can turn five degrees, or the sprocket can turn five degrees on the shaft? It's normal for the shaft to be able to turn at least that much, because of the way the shift dogs are made.
Old May 11th, 2017, 06:56 AM   #3
sobieski
Motorcycle(s): 250r
The shaft can rotate on its axis.
Just seems odd that I never noticed it before.
I put every one of the 40k miles on this bike myself.
But... I can roll with it, if it's not a problem.
Thanks
Last futzed with by sobieski; May 11th, 2017 at 06:58 AM. Reason: Typo
Old May 11th, 2017, 08:09 AM   #4
It's normal, and you'll find similar play in all gears. Some gears may have more than others.
Old May 14th, 2017, 10:27 AM   #5
sobieski
Motorcycle(s): 250r
I think the original symptom I had (which was a slight "bump" type sensation about 10 feet from starting fron a dead stop) was due to a dirty chain and possbibly a bit too much chain slack.
After cleaning, lubing and adjusting the chain, the symptom is gone.
The front sprocket play was simply a false decoy when looking for a cause.
Thanks all for your replies, etc.
Old June 7th, 2017, 10:10 PM   #6
Rear Sprocket Play onetruevibe 2008 - 2012 Ninja 250R Tech Talk 6 August 14th, 2011 04:14 PM
Front Sprocket Archerzz 1986 - 2007 Ninja 250R Tech Talk 66 June 29th, 2011 10:22 AM
Front sprocket, help!! cbowman78 2008 - 2012 Ninja 250R Tech Talk 34 November 14th, 2010 10:52 AM
front sprocket miniguns167 2008 - 2012 Ninja 250R Tech Talk 4 September 27th, 2009 11:59 AM
Swapping only the front sprocket. Obsidian 1986 - 2007 Ninja 250R Tech Talk 21 June 26th, 2009 10:22 AM
