May 20th, 2017, 09:19 AM | #1 |
Join Date: May 2017 Motorcycle(s): 2012 Ninja 250r Posts: 11
What is this green stuff on this tube?
I was taking apart my new bike to work on the carbs and saw this when I removed the left fairing. What tube is this, and what is this green stuff? How do I clean it?
May 20th, 2017, 09:26 AM | #2 |
It looks like the radiator hose has been oozing antifreeze at its clamps, causing the antifreeze to dry into a green crust.
Welcome to the board, Jacob. |
May 20th, 2017, 09:30 AM | #3 |
Thank you! I'm glad to be here, Jim. Do I just wipe away the antifreeze and tighten the clamps?
May 20th, 2017, 09:49 AM | #4 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Yes. Then ride for a while and verify no more oozing.
May 20th, 2017, 10:09 AM | #5 |
CCS Amateur #501
Join Date: Jun 2015 Motorcycle(s): '09 250 SE 'Booger' Posts: 406
Also check the coolant level both in the radiator cap and the reservoir. It could be empty or very low.
May 20th, 2017, 01:17 PM | #6 |
Track Clown
MOTM - Sep '15
coolant
I would drain the system and flush it, remove the tubes and clean them off. re-install and refill the coolant. |
[roadracingworld.com] - What's Better Than Cool Stuff? Cool Stuff For Free! Take The | Ninjette Newsbot | Motorcycling News | 0 | March 12th, 2014 12:20 AM |
coolant tube | joshuafrench | 1986 - 2007 Ninja 250R Tech Talk | 6 | December 23rd, 2013 01:57 AM |
Tube with amber stuff in it? | triptronix | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 16th, 2012 04:24 PM |
[topix.net] - From Twin-Tube Single Shocks to Single-Tube Twin Shocks: Ohlins... | Ninjette Newsbot | Motorcycling News | 0 | June 5th, 2012 04:30 AM |
[sportrider - latest stories] - From Twin-Tube Single Shocks to Single-Tube Twin Shoc | Ninjette Newsbot | Motorcycling News | 0 | June 4th, 2012 06:40 PM |
