May 20th, 2017, 12:46 PM | #1 |
Join Date: May 2017 Motorcycle(s): 2012 Ninja 250r Posts: 11
I can't move the air box back any further
As the title states, I am trying to remove my carbs and I can't get the air box any further back than I already have it. Where did I go wrong? Can I pull the carbs out right now?
(Those wires and that white strip along the frame is for an LED strip the previous owner installed) |
May 20th, 2017, 04:06 PM | #2 | |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
If you remove the two bolts at the bottom front of the inside of the rear fender it should loosen everything up enough to pull the entire airbox and fender assembly back out of the way. You're almost there. Bill |
Stock air box won't go back on... | monjorrow | 1986 - 2007 Ninja 250R Tech Talk | 8 | April 6th, 2015 12:23 PM |
air box | John D | 1986 - 2007 Ninja 250R Tech Talk | 10 | September 4th, 2012 08:07 PM |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
[superbikeplanet.com] - Oxygen! Come On People, Move Back! Give him Some Air! | Ninjette Newsbot | Motorcycling News | 0 | June 25th, 2010 01:30 PM |
