Old May 21st, 2017, 10:40 AM   #1
Speedy3
Motorcycle(s): 2008 Triumph Speed Triple (Blazing Orange); 2010 Nina 250r (Race Project)
Newgen 250, 204 ex300 fork swap?
Hello all, I have a fun for you!
Working on my SO's track bike. Just sold my speedy for a 300, so she is getting the 250!
Here is my predicament. The forks on the 250 are dialed in (to a point. Just have the right fork springs, oil level, weight and preload). The 300 is stock, perfect for her size.
Can I just take the forks off each and swap?
Worst case scenario I imagine the front where would have to go with, but if I could just swap the forks that would be ideal.
Speedy3 is offline   Reply With Quote
Old May 21st, 2017, 11:57 AM   #2
AchyGrappler
Motorbike Obsessed
AchyGrappler's Avatar
Motorcycle(s): 2004 Kawasaki EX250, 2004 Yamaha FZ1, 2006 Honda CRF 450 Flat Track Race Bike
I believe you can, however you have to look at all of the other factors like handle bar clearance etc. since you have to swap the whole thing over. Everything from the triple trees on down.
Do a search for pregen 17" wheel conversions. Many people talk about swapping new model forks onto the older model (pre '08) bikes to take advantage of the modern tires available in 17" sizes. You are essentially doing the opposite so many of the issues will be covered.
My race Ninja build and more motorcycle content. My Motorbike Obsessions
AchyGrappler is offline   Reply With Quote
Old May 21st, 2017, 03:42 PM   #3
Speedy3
I actually just said to heck with it and started. Here is what I discovered:
Forks swap cleanly.
Calipers bolt cleanly.
If this is a 300-to-250, you will have to find a way to hold the brake line and speedo cable away from the tire.
The fender-stay and gender have to go with the forks, unfortunately.
Old May 22nd, 2017, 06:40 PM   #4
Ram Jet
Ram Jet's Avatar
Forks swap cleanly.
Can't you just use the 250 guides. If you have to just drill two holes in the fender - they just snap in - as you know I'm sure.
Bill
Old May 22nd, 2017, 06:42 PM   #5
Speedy3
Bill
Bill,
Certainly can use the guides! If you take the 250 forks to the 300, your set. It's the 300 forks (with no guides on the fender) that leave you in a pickle. I need to look more into my scraps to see if there are parts to put o n the 250 to keep it sorted.!
Old May 22nd, 2017, 10:16 PM   #6
Ram Jet
Ram Jet's Avatar
Bill,
You can get the speedo and brake line guides at Partzilla.com. The drill you can get at Ace hardware :-) (joke).
Bill
Old May 22nd, 2017, 10:19 PM   #7
Speedy3
Bill
I will use this!
Old May 23rd, 2017, 10:25 AM   #8
bruce71198
bruce71198's Avatar
the 300 forks won't have the boss on the left fork leg to prevent the speedometer drive from spinning around. If you have the spacer from the 300 you can substitute it for the speedo drive. If your 300 is an ABS model the speed sensor will not mount to the 250 fork leg below the brake caliper.
Last futzed with by bruce71198; May 23rd, 2017 at 10:27 AM. Reason: more info
NewGen Fork Spring Rate Chart InvisiBill 2008 - 2012 Ninja 250R Tech Talk 6 May 30th, 2015 08:16 AM
WTB Right Newgen Front fork Floki Items Wanted 2 May 29th, 2015 05:36 PM
636 fork swap gt_turbo 2008 - 2012 Ninja 250R Tech Talk 22 March 16th, 2015 08:18 AM
636 fork swap pics gt_turbo Pictures 4 April 23rd, 2012 09:08 PM
fork springs - pregen vs newgen ReDnEcK 1986 - 2007 Ninja 250R Tech Talk 5 September 12th, 2010 02:39 PM
