Old July 22nd, 2010, 07:16 AM   #1
keeyu
Motorcycle(s): 250r
Shimming Needles @ NYC
Anyone from NYC who have done shimming the bike and wants to help me? Please PM me. I am located in Queens
keeyu is offline   Reply With Quote
Old July 22nd, 2010, 07:57 AM   #2
dubojr1
dubojr1's Avatar
Have you seen this thread? It's a great DIY.
http://www.ninjette.org/forums/showthread.php?t=11963
Old July 22nd, 2010, 09:21 AM   #3
keeyu
Motorcycle(s): 250r
Yes I have. I just need some help.
Old July 22nd, 2010, 09:23 AM   #4
wvninja
wvninja's Avatar
Motorcycle(s): 2009 Honda CBR600RR
Its really easy but I will admit I had someone helping me and the job only took 20 minutes give or take.
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja
wvninja is offline   Reply With Quote
Old July 22nd, 2010, 11:02 AM   #5
want1sobad
Ninjette CPT
want1sobad's Avatar
Motorcycle(s): Black 08 250r
kenny, i understand your hesitation about tearing into the bike (i felt the same way). honestly, it is very easy if you read through the DIY a few times and understand the process completely. take your time, stay organized, above all else use the right tools (milwaukee offset screwdriver). otherwise you will turn a very simple mod into a huge headache (ask me how i know). you will be amazed at the difference shimming and pulling the snorkel will have on your stock ninja.
DO IT!
want1sobad is offline   Reply With Quote
Old July 22nd, 2010, 11:08 AM   #6
Kitdog
Kitdog's Avatar
Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color
I have to agree, read it a few times and then just give it a shot! just make sure you have the right tools, and take your time. I was terrified about doing as well but once I got up the guts the job is really easy... Dealing with the cheep Phillips head Jis screws is the real nightmare! Kkim is the 250 guru and can help you fix almost anything that might go wrong!
"Well you know, for me, the action IS the juice"
Kitdog is offline   Reply With Quote
Old July 22nd, 2010, 11:17 AM   #7
dubojr1
dubojr1's Avatar
All hail kkim...
Old July 22nd, 2010, 11:30 AM   #8
want1sobad
Ninjette CPT
want1sobad's Avatar
kelly is YODA
Old July 22nd, 2010, 11:45 AM   #9
dubojr1
dubojr1's Avatar
More good information of the tools...
http://www.ninjette.org/forums/showthread.php?t=49003
Old July 22nd, 2010, 11:52 AM   #10
Kenny... are you having "drivability" problems with the bike?
if you've never worked on bikes or cars before, this could be something you might not want to do unless you're experiencing some sort of problems.
saying that, if you do want to do this and need help, we're all here to answer any questions you may have. if you do a search, there are many threads on ninjette that you can research for info so you can get a clear idea of what's involved and what you can expect as far as difficulty doing the mod and what to expect as a result of your work.
It's great feeling to work on your own bike, "improve" it and feel the satisfaction of knowing you did it yourself. There is also that awful feeling in the pit of your stomach when you do something to the bike that renders it to very nice paperweight.
Before anyone does any mod, they should research the work carefully and have a clear idea in their mind on how to accomplish the task.
gl... let us know if/how we can help.
Old July 22nd, 2010, 11:59 AM   #11
keeyu
Motorcycle(s): 250r
Which tool set should i buy?
Old July 22nd, 2010, 12:11 PM   #12
basic tools... what tools do you have now? experience level?
I highly recommend some JIS screwdrivers, though it can be done without. The biggest stumbling block/headaches people have had doing this mod has been from stripping the screw heads on the top of the carbs.
You'll also need about 6- #4 or 3mm washers.
Old July 22nd, 2010, 12:12 PM   #13
dubojr1
dubojr1's Avatar
Personally I bought the offset driver from Home Depot. Loved it! Works great and comes with the proper JIS bit.
I also bought one of these (see link below) as it made it even easier to turn the screws out without your hands slipping on the regular bit driver that is also needed with the offset driver. Hope this helps.
http://www.homedepot.com/Tools-Hardw...atalogId=10053
Old July 22nd, 2010, 12:22 PM   #14
dubojr1
dubojr1's Avatar
I found my washers at Lowe's in the specialty hardware section...
http://www.lowes.com/pd_136250-37672...steel%20washer
Old July 23rd, 2010, 12:31 PM   #15
keeyu
Motorcycle(s): 250r
Thanks..I bought everything. I got the washers from Radioshac. WIll those work?
Old July 23rd, 2010, 12:40 PM   #16
which washers did you buy... exactly? like I said in my post, are they SAE #4 washers or metric 3mm? either of those 2 choices will work.
Old August 14th, 2010, 02:29 PM   #17
keeyu
Motorcycle(s): 250r
Finally did it and de-snorkel. WOW. What a difference. Thanks everyone.
Old August 14th, 2010, 03:58 PM   #18
Old August 17th, 2010, 07:40 AM   #19
illrational
illrational's Avatar
Motorcycle(s): Black '11 ZX-6R
Wow seeing his Keeyu's reaction has me definitely doing mine this weekend. I'll let everyone konw how it turns out. Dubojr1, what game?
My 250 is mine and mine alone, you may see better you'll definitely see worse but mine, she's one of a kind!!!!btw, SHE'S SEXY!!!
illrational is offline   Reply With Quote
Old August 17th, 2010, 07:54 AM   #20
dubojr1
dubojr1's Avatar
I'm planning a thread for "Spot the Mods"
I'll be posting a few new pics shortly and asking if all the mods can be found. Had to edit my signature for now cause all my mods were in there. Just hoping it could a be a fun little game. Something different.
Old August 17th, 2010, 08:16 AM   #21
wvninja
wvninja's Avatar
Do it, its easy and well worth it! Having a friend over just makes things go even faster (tearing off both side at the same time, someone handing you tools, ect)
Old August 17th, 2010, 08:37 AM   #22
illrational
hvn problems findn stre in my area that sell jis screw bits
Old August 17th, 2010, 08:51 AM   #23
wvninja
wvninja's Avatar
I didn't need any, I just had a really long screwdriver and different size ends to put on it
Old August 17th, 2010, 08:55 AM   #24
dubojr1
dubojr1's Avatar
Any Lowes, Home Depot, or Ace Hardware should have them.
Old August 17th, 2010, 11:50 AM   #25
keeyu
Motorcycle(s): 250r
I bought mine online. I still stripped some of the screws.
Old August 17th, 2010, 12:14 PM   #26
greg737
Motorcycle(s): -
You don't have to find JIS type screwdrivers, instead go back to Home Depot and pick up drywall driver bits in the two smaller sizes. Drywall driver bits are are very cheap and they're a perfect substitue for JIS (Japanese Industrial Standard) screwdrivers. The Drywall driver bits have the same squared-off and aggressive profile as the JIS screwdrivers. All the screws on the carbs are JIS.
Or you could chose not to make the trip to Home Depot and use your Philips screwdrivers instead. The job will take a little longer because you'll "cam-out" almost every screw you try to remove.
Shimming the carb needles kfilla General Motorcycling Discussion 2 July 2nd, 2014 06:14 PM
Shimming same with Jetkit Needles? vmax 2008 - 2012 Ninja 250R Tech Talk 4 August 1st, 2013 11:49 PM
question about shimming those needles fizzer914 2008 - 2012 Ninja 250R Tech Talk 6 June 11th, 2012 03:12 AM
DJ Needles instead of shimming mxman38 2008 - 2012 Ninja 250R Tech Talk 7 May 30th, 2012 07:09 PM
Shimming the needles question Tubesock 2008 - 2012 Ninja 250R Tech Talk 20 August 15th, 2009 12:17 PM
