Old June 27th, 2013, 09:19 PM   #1
w8ting4fri
Motorcycle(s): 2002 Ninja 250
A couple of questions about my first bike.
I recently bought a 2002 Ninja 250. I have a couple questions about it.
1. It does not have front turn signals. Where could i get new flush mounted signals for it? (or even stock ones.)
Also how should I go about replacing them?
2. The throttle wont return. Is it most likely some dry throttle cables?
3. What oil filter is recommended for it?
Any help would be appreciated thanks!
w8ting4fri is offline   Reply With Quote
Old June 28th, 2013, 04:37 AM   #2
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
1. ebay
2. That or routed incorrectly
3. Fram ch-6012 (also fram ch-6009 works)
j98sprint is offline   Reply With Quote
Old June 28th, 2013, 08:19 AM   #3
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Eden Prarie, I live just down the road a bit (1550 miles).
Old June 28th, 2013, 09:04 AM   #4
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Guys above are right. You can also pick signals up from other members...
Old June 28th, 2013, 09:28 AM   #5
w8ting4fri
Thanks guys I think the bigger problem will be installing them.
I just thought of one more thing. The turn signal light doesn't work, is this because the front turn signals aren't installed or is it a bigger issue?
Thanks again!
Old June 28th, 2013, 09:39 AM   #6
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
1. Ebay, forums (like here, check the classified), SportbikeTrackGear.com, Rider's Discount, etc
2. Possibly, but check the obvious and simple stuff like the grip if it's rubbing against the throttle tube housing. If it's not, then I would check routing. If routing looks good, pull the tank and look to see if the cable housing has any sharp kinks or folds. If not, try lubing the cable with a Motion Pro cable lube tool and some Motion Pro cable lubricant. Best stuff ever. Lubed it once and never had to relube...and this is from a bike I had and the last time I lubed it was over 5 years ago
3. Wix, Purolator Pure One (check the Calsci forum and list of filters). There is also a FAQs on here and a Ninja Wiki and FAQs. Do some googling.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Bike Question Vad18 2008 - 2012 Ninja 250R Tech Talk 4 April 4th, 2014 08:45 AM
Stupid first bike question Rys General Motorcycling Discussion 21 October 26th, 2011 02:51 AM
[topix.net] - Bike couple's 17,000 mile journey Ninjette Newsbot Motorcycling News 0 July 21st, 2010 08:00 AM
crashed my bike a couple of weeks ago eddylz18 2008 - 2012 Ninja 250R Tech Talk 5 May 23rd, 2009 09:53 AM
[visordown.com] - Benefit cheat bike couple appear in court Ninjette Newsbot Motorcycling News 0 March 10th, 2009 01:31 AM
