#1 |
Join Date: Mar 2011 Motorcycle(s): 96 Ninja 250EX , 87 CBR 1000, 86 TRX 260R, 86 KXT 250, 84 ATC 200X, 82 ATC 250R (w/CR480) Posts: 134
Performance mods on pre gen
Ok other than the basics like pod filters and exhaust.. What options are out there to boost performance in a pre gen motor... Pistons, cams, head work Ect... I'm trying to get most out of motor without sacrificing reliability... How about sources.. Any members here do this type of work ... Give me some options .. Thanks
#2 |
Join Date: Mar 2011 Motorcycle(s): 2007 ninja 250r Posts: 374
Best performance mod you can do is become a better rider.
ss brake lines and good tires will be way better then anything else you do to the bike. |
#3 |
http://faq.ninja250.org/wiki/Bike_mods_for_beginners
http://faq.ninja250.org/wiki/Why_per...e_good_for_you http://faq.ninja250.org/wiki/Can_I_i...ole_jet_kit%3F http://faq.ninja250.org/wiki/Battery...r_carb_removal http://faq.ninja250.org/wiki/I_want_...uretor_jetting
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí Last futzed with by Motofool; April 25th, 2013 at 11:45 AM. Reason: Changed directions on type of advice |
#4 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Given the extensive bike list I wonder if the OP is a veteran.
If so, a good question would be what will be the planned usage of the motorcycle?
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
#5 | |
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#6 |
Thanks for the links fool.. Ill check them out ...
As far as usage I picked up a few motors the other day one to replace the one I shelled in the ninja ... The other is going to be for a project I'm going to make a street tracker out of .... Similar to this one pictured. ![]() Mainly used for commuting around town but I may take it up and actually put some time in at the dirt track.. Possibly even hit the ice with it... So I want to really squeeze all the hp I can out of the motor I'm aware of the basics filters pipes jetting ect but I'm looking to really try and maximize hp ... Pistons ,cams ,head work ,back cut gears ect. Is there stuff on the market for this and is the gain worth the cost... And I still want to run on pump gas I do have plenty rider experience .. Lol .. Like fool said been riding almost 30 years I have rode and raced everything with 2 3 and 4 wheels on pavement dirt and ice ... I've held mra licenses .. I currently been running quad c class colorado off road championship series... I ice race 2-3-4 wheels. 2008 colorado state ice racing champ novice bare tire class... And I leave Wednesday with a load of vintage ATC's (three wheelers) headed for Utah to hit the dunes and then to Idaho in June.... Plenty of experience here and that being said still learn new stuff every time I head out |
#8 |
time is running out....
Join Date: Sep 2012 Motorcycle(s): pregen ninjari Posts: 412
i was about to make the same thread.
i have an 04 pregen. not to thread jack. very relative. what is the std bore for our motors? 62mm? and compression? i see some 66mm 13.1 pistons on ebay. might have to do E85 or 93 octane though. cams? having trouble finding sellers and parts. iv built motors for cars before. bike stuff couldnt be harder. take apart and clean take to shop, have them bore and hone to pistons you bring them. new gaskets, oil pump, chain tensioner, chain. reassemble with new bearings and rings. assemble, tune carbs to match, brap brap
The King |
#9 | |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
#10 | |
![]() Quote:
![]() For those purposes, and unless you will try for 105 mph commuting around town, on dirt and on ice, you may want to consider gaining torque at the expense of final speed via a bigger rear sprocket (may need a new, longer chain).
#11 |
sail away
From the wikipedia:
Bore and Stroke 62.0 mm × 41.2 mm (2.44 in × 1.62 in) Compression Ratio 12.4:1 The availability of parts for the 2008-2012 J-gen is much better than for the 87-07 F-gen. I think you will have a lot of difficulty finding aftermarket engine parts for the F gen. You may want to look for interchangability unless you want to have them built by a machinist. If you go the machinist route, I personally don't think the gains will be worth it. If you foresee spending any more than $4k you might as well get a 300, which has improvements across the board and higher potential gains from modifying the larger displacement engine. Suspension work may get you from point A to point B a lot faster though, assuming there are curves in between.
#12 |
ebay has pistons of 66mm n 13.1 cr ..hmmm
shops dont cost much. i jus had a gsr motor punched out from 81mm to 82mm with 12.1cr cost about $140 with cleaning. then3pistonsxx. gaskets.bearings. no more then 800total if ur smart small motorcycle block cofuldnt be more. assemble myself. its like a lego set. $3-4k? uh ..no or jus do a ex500 swap
The King Last futzed with by rabies; April 26th, 2013 at 10:24 PM. |
#13 |
Thanks guys for all the comments ... I have seen that bike for sale .. As far as legality here in colorado their pretty easy to get along with here headlamp mirror and tail lamp is all that is required... I think that I'm gonna take several of his ideas and incorporate them into a build .. my brother works for a company that fabricates tanker trailers so i get all aluminum at scrap prices.. and one of his guys said he would tig the tank and body work for me... mmmm bare aluminuw all tigged up would look sweet...I'm starting with just a motor and a bare rolling frame and going from there I have a uline on a few nice pre gen rollers here... I guess it is what it is on these motors... Allthough I'd like more hp ill just deal as It will only be a ocassional cruiser .. I still can ride my girls 250 or my cbr 1000 if I want to get somewhere fast....
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. | AFazakerley | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 5th, 2016 02:03 PM |
Fitting a new gen front wheel on a pre gen? | thumper64 | 1986 - 2007 Ninja 250R Tech Talk | 13 | November 6th, 2013 02:44 PM |
Bike size, new gen vs pre gen(zzr) | bowerbird100 | General Motorcycling Discussion | 6 | August 1st, 2013 05:49 PM |
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames | kjohng | General Motorcycling Discussion | 5 | February 27th, 2013 10:03 AM |
FS/ part out new gen and pre gen 250r ninja | carlos | Motorcycle-related | 3 | May 14th, 2012 10:25 PM |
