Old March 28th, 2012, 10:25 PM   #1
jboyd12
jboyd12's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250 Special Edition
Valve Cover Block off Plates / Crankcase Breather ?
Is there any advantage to using block off plates like many people do to the 600 bikes? I was thinking about capping this off. I know many people do it on the zx6s to get rid of the emissions stuff to get a more accurate air fuel ratio. But it looks like this is just putting hot air from the valve cover into the airbox. If I cap this off, will it be beneficial or harmful?
Now my Crankcase breather question:
Theres also a hose coming off the crankcase to the airbox. I was wondering if I disconnected it from the airbox and used a smaller filter for itself could it be more efficient and potentially increase power due to lower air temps?
jboyd12 is offline   Reply With Quote
Old March 28th, 2012, 10:34 PM   #2
headshrink
headshrink's Avatar
Several of us use a block off plate. I did it mostly to minimize the junk and a plate is nicer looking than just plugging it. There is no noticeable difference in performance, at least as far as I can tell. Supposedly this was a solution to some decel popping for those who didn't want to really get in and re-jet after modding their intake.
As far as the little filter on the crank case, I have no idea; but I imagine it would make even less of a difference.
Old March 28th, 2012, 10:39 PM   #3
jboyd12
jboyd12's Avatar
Thanks for the info, but one more quick question:
Is this supposed to be open like that?
It seems like there should be something connected to it..
Old March 28th, 2012, 10:46 PM   #4
quanttrom
Motorcycle(s): 250r
mine is open just like that
quanttrom is offline   Reply With Quote
Old March 28th, 2012, 11:37 PM   #5
headshrink
headshrink's Avatar
I don't remember, but I think it was open also.
Old March 29th, 2012, 08:57 AM   #6
drvr5
Motorcycle(s): '09 250 Green+Black Special Edition
Yes, that's supposed to be open.
Any performance gains you get from filters/blockoff plates would be immeasurable- but the theory is sound, so go ahead and do it anyways. If there isn't a reason you're keeping the stock air box- k&n r-0990 pod filter makes a noticeable difference through the whole power band, and is about $30. Shimming needles is required, rejetting is highly suggested. Both of the mods you are talking about are required when switching over to a pod.
drvr5 is offline   Reply With Quote
Breather hole in block..?? Josh_kcco 1986 - 2007 Ninja 250R Tech Talk 11 August 21st, 2014 11:54 AM
Cleaning Crankcase Breather indr 2008 - 2012 Ninja 250R Tech Talk 6 January 10th, 2013 06:50 PM
Crankcase Breather POD zzrguy 1986 - 2007 Ninja 250R Tech Talk 7 May 2nd, 2012 10:28 AM
Is a K&N Crankcase breather filter? Suave 2008 - 2012 Ninja 250R Tech Talk 10 July 6th, 2011 09:12 PM
K&N Crankcase/Breather Filter nyczs2k Motorcycle-related 6 February 5th, 2011 02:04 PM
