February 23rd, 2013, 06:39 PM | #1 |
Join Date: Jun 2012 Motorcycle(s): 09 Ninja 250r Posts: 70
Im stuck: removing the carbs
Well, i've got the bike stripped down as far as I ever have. I'm trying to remove the carbs. Tank is off, but now I have to move the air box back so I can pull the carbs off. I watched the DIY video, but that doesn't really help since I have the stock air box. How do I move the air box out of the way so I can pull the carbs out?
February 23rd, 2013, 11:20 PM | #2 |
Join Date: Jul 2012 Motorcycle(s): 2009 Ninja 250R SE Posts: 262
February 24th, 2013, 01:54 AM | #3 |
Unscrew the 4 screws attaching the carb to the air box and engine. I don't really remember but you should be able to slide it back at this point, don't think you are going to be able to move it far it is literally less than an inch. Make sure you pull out the carbs from the left side of the bike it will take some finagling. I hope you have small hands. Post pics if you have any specific problems.
Edit: by 4 screws I mean the round metal circles clamping the rubber gasket type things to seal the carbs to the engine/airbox. Sorry if I am vague I'm trying to go straight off memory from doing it 6 months ago. |
Stuck bikeless | Toly | The Ex-Ninjetters Lair | 18 | January 29th, 2015 07:44 PM |
Removing the carb-without removing airbox? | tuscani451 | 2008 - 2012 Ninja 250R Tech Talk | 10 | July 6th, 2014 05:11 AM |
Removing and cleaning carbs and K&L Repair Kits | peterpayne | 1986 - 2007 Ninja 250R Tech Talk | 4 | November 4th, 2013 03:49 AM |
Removing Mirror Bracket (with removing all the fairings) | killermase | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 21st, 2012 11:16 PM |
removing a stuck bolt? | alex.s | General Motorcycling Discussion | 27 | April 5th, 2012 04:38 PM |
