December 7th, 2012, 01:51 PM | #1 |
Join Date: Jul 2012 Motorcycle(s): 2013 honda shadow phantom Posts: 170
turn signal help
okay so both my turn signals (front and rear) are 12v 23w but everytime i use my blinker a grinding noise happens where the turn signal relay is (and blink rly fast). do i have to replace the bulbs or could i replace just the turn signal relay? also would i have to replace a fuse or anything else? and would my bikes battery handle this?
reason id rather just replace those parts is because i cannot find a replacement thats 12v 10w. |
December 7th, 2012, 02:00 PM | #2 | |
Fast-Guy wannabe
MOTM - Jan '13
December 7th, 2012, 02:09 PM | #3 |
December 8th, 2012, 10:10 AM | #4 |
k think if i just get a relay the noise and fast blinking will stop and i believe thats all i need to do
December 8th, 2012, 10:46 AM | #5 |
Certified looney toon
MOTM Jul '13, Jul '14
I had a similar issue with my aftermarket signals. It's drawing too much for the thermal relay. Pop down to an auto parts store with your two prong relay and pick up an electric relay. The electric one has the stock sounding click and a steady slow blink.
Only downside will be the lights will continue blinking even if one is burnt out, whereas right now, the one not burnt will come on solid and not blink.
December 9th, 2012, 07:50 AM | #6 |
yep that fixed it just put in a new relay and its good now
February 18th, 2013, 06:11 AM | #7 |
February 20th, 2013, 06:23 AM | #8 |
i used the tridon ep34: http://www.autozone.com/autozone/par...dentifier=6416
u have to ground one of the terminals, more detail here : http://www.ninjette.org/wiki/L.E.D_Lighting are any of them leds? |
February 20th, 2013, 04:56 PM | #9 | |
i also have two resistors on each side. ( 4 in total) |
February 21st, 2013, 05:03 AM | #10 |
should be good to go then with those resistors on, maybe the relay u got was a bad one. try the tridon one i linked just ground the 3rd pin with some wiring and a ring connector.
February 21st, 2013, 10:08 AM | #11 |
February 24th, 2013, 09:37 AM | #12 |
guys, i bought this flasher : http://www.ebay.com/itm/170936578711...84.m1439.l2649
i put off all the resistors. then i put on this relay(it says that it is electronic) but nothing happens. i mean the turn signals wont even turn on. they are "dead"!!!! what is the problem?? im getting mad with this situation!!! maybe the flasher isnt right?? please heeeeeelllpppp!!! |
February 24th, 2013, 09:08 PM | #13 | ||
ModMy250.com
The www.ModMy250.com guy |
February 25th, 2013, 04:08 AM | #14 | |
it looks like dead!! |
February 25th, 2013, 07:23 AM | #15 |
ModMy250.com
Did u turn ur bike on? What did you ground the e pin to? Try grounding the other pin.
February 25th, 2013, 03:20 PM | #16 | |
and nothing happens. could you please suggest me an electronic flasher 2 pin that matches with my bike? in ebay please. i want to buy a flasher that will surely work!! not 3 pin, but 2 pin , i want it plug n play! thank you very much!! |
February 25th, 2013, 03:27 PM | #17 |
Fast-Guy wannabe
MOTM - Jan '13
Plug and play, it what I and many others used http://www.superbrightleds.com/morei...asher/781/835/
February 25th, 2013, 03:32 PM | #18 |
Join Date: Oct 2012 Motorcycle(s): White 2013 Ninja 300(Storm), Silver 2003 Fjr1300 Posts: 173
Or go to Tri's websight thats where I got mine.
ATGATT For all I know, women who ride motorcycles are all man-hating dominatrix's. It was like a mild panic attack! |
February 25th, 2013, 04:04 PM | #19 | |
should this work? 1)http://www.patronos.gr/uploads/image...LED%202plo.JPG 2)http://www.moto-rider.com/product-view.aspx?pid=31882 --> is that the same of the one you told me to buy? they look like i think (because a market near my home sells a relay like this and i prefer to buy it from there so i can fix my motorcycle tomorrow. if it doesnt fit i will buy the relay above(http://www.superbrightleds.com/morei...asher/781/835/). please your help!! |
February 25th, 2013, 05:14 PM | #20 | |
Fast-Guy wannabe
MOTM - Jan '13
February 25th, 2013, 05:32 PM | #21 |
thats ok. and one last question.
the leds have one yellow cable, and one black/yellow. ninja 250r has one black and one green. what goes with what?? and i have 4 led turn signals. should i use any resistor with this: http://www.superbrightleds.com/morei...asher/781/835/ or just plug the flasher? sorry for so many questions!! thank you for everything!! |
February 25th, 2013, 05:38 PM | #22 |
Fast-Guy wannabe
MOTM - Jan '13
I'd say black to black & yellow and yellow to green but you may want to comfirm with the maker of the LEDs which is supposed to go to positive and negive then confirm on the bike the matching polarity with ether the wiring diagram or voltage meter.
February 25th, 2013, 05:47 PM | #23 | |
February 25th, 2013, 05:56 PM | #24 | |
Fast-Guy wannabe
MOTM - Jan '13
February 25th, 2013, 06:09 PM | #25 |
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
Turn signal issue... | YMCMB | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 21st, 2012 04:58 PM |
Turn signal terminal | Avenged7Fold | 1986 - 2007 Ninja 250R Tech Talk | 4 | June 6th, 2012 04:34 PM |
will this turn signal work | skateboarder1210 | 2008 - 2012 Ninja 250R Farkles | 12 | June 29th, 2011 08:52 PM |
Turn signal went out, looking for a new turn signal | austinm911 | 2008 - 2012 Ninja 250R Farkles | 3 | January 23rd, 2011 08:58 PM |
