Old February 17th, 2013, 01:45 AM   #1
tubarney
How do you remove your engine
I have taken the head and block off. All i'm left with is a crankcase. How do you get the crankcase off the frame?
Am i going to need to drop in onto a stand or will I be able to be able to hold the case using my arms? How heavy is this thing?
Old February 17th, 2013, 01:59 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Just put a jack under the engine and remove the long bolts at the back. It's not that heavy. But you will need the jack to hold it when you want to it it back.
Worlds fastest 250 ninja
Old February 17th, 2013, 06:36 AM   #3
Before you remove the bolts, make sure that every hose and cable are disconnected.
Nothing like pulling that last bolt out and grab the engine to find it still attached to the frame.
Old February 17th, 2013, 07:15 AM   #4
tubarney
Thanks.
Can you recommened a flywheel puller or holder? Do you use these tools?
Old February 17th, 2013, 07:40 AM   #5
Racer x
Racer x's Avatar
I have a flywheel puller from motion pro. It fits but you need an impact gun and torch to pop the flywheel off. I have not gotten one off yet. I work around it.
Old February 17th, 2013, 07:46 AM   #6
tubarney
is it possible to split the case leaving it in?
Old February 17th, 2013, 08:50 AM   #7
Racer x
Racer x's Avatar
NO
But You can flip the fully assembled engine upside down and remove the bottom half of the case. . That gives you full access to the crank and trans. Also oil and water pump stuff and shifter.
Old February 18th, 2013, 05:58 PM   #8
tubarney
im confused, how do you get the bottom of the crankcase off without splitting it.
Old February 18th, 2013, 06:13 PM   #9
indr
You need to remove the flywheel and the clutch basket in order to split the crankcase. This is better done with the engine still on the frame so it's secure while you use a breaker bar on it.
You also need to remove the crankcase from the frame to split it because there is an engine mounting bolt that goes through the top half of the crankcase, and there is one that goes through the bottom half.
indr is offline   Reply With Quote
Old February 18th, 2013, 06:41 PM   #10
Samer
Samer's Avatar
Motorcycle(s): 09 Ninja 250R SE
Just curious,
Why are you taking the engine out? Seems like you have a pretty new bike.
Samer is offline   Reply With Quote
How to remove the carbs cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 1 July 1st, 2014 07:10 PM
How do I remove this reroka 2008 - 2012 Ninja 250R Tech Talk 7 June 10th, 2014 06:58 PM
Another way to remove the carbs.... Soujyu 2008 - 2012 Ninja 250R Tech Talk 6 August 26th, 2013 12:36 PM
To remove or not to remove?? extremez31 General Motorcycling Discussion 13 April 18th, 2012 07:54 AM
How do you remove the grip? CThunder-blue 2008 - 2012 Ninja 250R Farkles 29 August 16th, 2011 07:35 PM
