February 17th, 2013, 10:19 PM | #1 |
My jigglets are jiggled
Join Date: Aug 2012 Motorcycle(s): 2009 SE 250R, Sym Mio 50 (scooter!) Posts: 28
Is it possible to install flush mounts without drilling into the fairings?
Again... it's because I don't have many tools to access and don't feel like paying the dealer/mechanic $90/hour for the job.
All the YT vids I've seen require drilling... hmmm.
Paddling gets me wet |
February 18th, 2013, 08:01 AM | #2 | |
Join Date: Jun 2012 Motorcycle(s): 2012 Ninja 250 Posts: 52
http://www.motorcycle-superstore.com...n-Signals.aspx |
February 18th, 2013, 12:26 PM | #4 |
Join Date: Jul 2011 Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636 Posts: 661
+1 for Tri's flushmounts. |
February 18th, 2013, 01:11 PM | #5 |
No cut protons on my bike, the same link I posted previously.
February 20th, 2013, 06:17 AM | #6 |
Join Date: Jul 2012 Motorcycle(s): 2013 honda shadow phantom Posts: 170
i ordered some bikemaster universal flushmounts and love the look of them. the tape that comes with them sux tho but some 3m permanent outdoors tape has held them on thro multiple washes driving thro rain and high speeds. one thing to keep in mind tho that depending on wattage of the bulbs in the flush mounts u get or if they are led you may need a new flasher relay to make them blink at appropriate speed, very easy task tho and lots threads here on how to do it.
February 20th, 2013, 10:51 AM | #7 |
Join Date: Mar 2011 Motorcycle(s): 2011 Kawi 250 SE Posts: 105
February 20th, 2013, 07:08 PM | #8 |
February 20th, 2013, 07:33 PM | #9 | |
Join Date: Oct 2012 Motorcycle(s): White 2013 Ninja 300(Storm), Silver 2003 Fjr1300 Posts: 173
February 20th, 2013, 10:41 PM | #10 |
Do the protons require wiring a relay or anything or do they just wire up directly to the stock harness?
February 20th, 2013, 10:52 PM | #11 |
Yes, I believe they need a replacement flasher relay that can handle LEDs (not a thermal relay like the stock one). Even if they had some kind of internal flasher unit, your rear turn signals don't. The only way they could work with the original relay is if they simulated the same load as the bulbs did and they would need to generate heat to do that (load resistors).
February 21st, 2013, 01:07 PM | #12 | |
ModMy250.com
The www.ModMy250.com guy |
February 22nd, 2013, 09:44 AM | #13 |
February 22nd, 2013, 01:19 PM | #14 |
Knee-dragger in Training
Join Date: Jul 2012 Motorcycle(s): '09 Ninja 250R (Sunbeam Red) Posts: 319
Very nice. What tank hugger is that? Been lookin' to get one.
North GA Riders |
February 22nd, 2013, 04:03 PM | #15 |
February 22nd, 2013, 05:01 PM | #16 | |
Also just curious, did it come in two pieces like that or did you have to modify it?
North GA Riders |
February 22nd, 2013, 05:36 PM | #17 |
February 23rd, 2013, 02:55 PM | #18 |
Join Date: Nov 2011 Motorcycle(s): Ninja 250r Posts: 152
You can also use tape from M3... i got 2 rolls of the same that GoPro uses on their "mount pads". Used mine for 1 year now, in 15.000km in rain... they just stick harder and harder the more they sit :P
February 25th, 2013, 04:46 PM | #19 | |
Flush Mounts?! | scubaru | 1986 - 2007 Ninja 250R Farkles | 62 | January 1st, 2014 02:39 PM |
Flush Mounts | fredhsu | 2008 - 2012 Ninja 250R Farkles | 16 | August 27th, 2012 10:55 AM |
Cool way to install flush mounts (BikeMaster Universal) | Maielstrom | 2008 - 2012 Ninja 250R Farkles | 33 | July 6th, 2012 05:43 PM |
Bikelitez flush mounts... Anyone done this? | KirkyPerk23 | 2008 - 2012 Ninja 250R Farkles | 1 | January 12th, 2012 04:28 PM |
Flush Mounts for 500 | reondadomino | General Motorcycling Discussion | 9 | December 19th, 2009 03:01 PM |
