February 18th, 2013, 01:24 PM | #1 |
Join Date: Oct 2012 Motorcycle(s): 2006 R6 Anniversary Edition Posts: 16
Shogun S5 Frame Slider Bolts
I crashed and destroyed my frame slider cap as well as the bolts that hold it in. How do I find out what the specifications are of the bolt so I can find replacements?
They're the 5 bolts that hold the cap in place on the end of the frame slider. Thanks |
February 18th, 2013, 01:45 PM | #2 |
Fast-Guy wannabe
MOTM - Jan '13
Remove one of you upper bodywork bolts that require a 4mm Allen wench and on of you lower body work bolts that require a 5mm Allen wrench. If the smaller one breads in then you need M5x0.8 bolts if the larger one threads in you need M6x1.0 bolts. Both are quite common and you should have any trouble finding them.
February 18th, 2013, 01:47 PM | #3 |
Fast-Guy wannabe
MOTM - Jan '13
These are M5x0.8
These are M6x1.0 |
February 19th, 2013, 05:55 PM | #4 |
I bought some M5 0.8 bolts but the head is too big to fit into the frame slider cap. Where can I get that specific type of bolt? The standard M5 0.8 threads in fine but the cap is too big.
February 19th, 2013, 06:28 PM | #5 |
Fast-Guy wannabe
MOTM - Jan '13
Just grind away a little material from the OD of the heads and they'll fit right in. Some heads are smooth and some have this tiny knurling to make it easier to grip by hand. The smooth ones are slightly smaller then the knurled so you just need to grid of the knurling.
You did get the same style heads and some other button or countersink style heads right? |
February 19th, 2013, 08:08 PM | #6 | |
February 19th, 2013, 08:40 PM | #7 | |
Fast-Guy wannabe
MOTM - Jan '13
Have you tried asking the manufacturer if they could supply you with replacement bolts? |
February 19th, 2013, 08:59 PM | #8 |
Fast-Guy wannabe
MOTM - Jan '13
here's the spec page or the head and thread dimensions http://www.mcmaster.com/#91251aac/=ljyogl
try the page http://www.mcmaster.com/ and in the find box in the upper left enter 91292A126 that should take you to the stainless steel version of what your looking for. What you bought looks like it uses a 5mm allen instead of a 4mm. The M5x0.8 bolts under this page use a 4mm allen so it should be very close if to a correct match. But take note that they will be a silver color and chance are if they're knurled you'll need to sand or grind that off to get them to fit. plus for $7 you get 100 bolts so you can open shop and start selling them yourself |
February 20th, 2013, 10:53 AM | #9 | |
February 20th, 2013, 04:49 PM | #10 |
Where does it say on that site whether it's fully threaded or partially threaded?
February 20th, 2013, 09:53 PM | #11 |
Fast-Guy wannabe
MOTM - Jan '13
At the very bottom of the page it tells you if it has a red * next to it then its fully threaded.
Shogun frame slider - 08-12 | Bigballsofpaint | Motorcycle-related | 17 | May 10th, 2015 08:11 PM |
Shogun frame slider differences | Bob2010 | 2008 - 2012 Ninja 250R Farkles | 6 | July 20th, 2014 08:17 AM |
Shogun Frame Slider Set 08+ | Fly'in Ninja | Motorcycle-related | 7 | April 25th, 2011 11:25 AM |
Shogun frame slider frame bolt question | crankinaway | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 22nd, 2010 06:46 PM |
Shogun Frame Slider Replacements | paterick4o8 | 2008 - 2012 Ninja 250R Farkles | 2 | August 13th, 2009 05:57 PM |
