Old February 23rd, 2013, 06:39 PM   #1
PistolPete93
PistolPete93's Avatar
Motorcycle(s): 09 Ninja 250r
Im stuck: removing the carbs
Well, i've got the bike stripped down as far as I ever have. I'm trying to remove the carbs. Tank is off, but now I have to move the air box back so I can pull the carbs off. I watched the DIY video, but that doesn't really help since I have the stock air box. How do I move the air box out of the way so I can pull the carbs out?
PistolPete93 is offline   Reply With Quote
Old February 23rd, 2013, 11:20 PM   #2
msebastian
msebastian's Avatar
Motorcycle(s): 2009 Ninja 250R SE
Follow this
http://www.ninjette.org/forums/showthread.php?t=11899
msebastian is offline   Reply With Quote
Old February 24th, 2013, 01:54 AM   #3
xaple
xaple's Avatar
Unscrew the 4 screws attaching the carb to the air box and engine. I don't really remember but you should be able to slide it back at this point, don't think you are going to be able to move it far it is literally less than an inch. Make sure you pull out the carbs from the left side of the bike it will take some finagling. I hope you have small hands. Post pics if you have any specific problems.
Edit: by 4 screws I mean the round metal circles clamping the rubber gasket type things to seal the carbs to the engine/airbox. Sorry if I am vague I'm trying to go straight off memory from doing it 6 months ago.
xaple is offline   Reply With Quote
Stuck bikeless Toly The Ex-Ninjetters Lair 18 January 29th, 2015 07:44 PM
Removing the carb-without removing airbox? tuscani451 2008 - 2012 Ninja 250R Tech Talk 10 July 6th, 2014 05:11 AM
Removing and cleaning carbs and K&L Repair Kits peterpayne 1986 - 2007 Ninja 250R Tech Talk 4 November 4th, 2013 03:49 AM
Removing Mirror Bracket (with removing all the fairings) killermase 2008 - 2012 Ninja 250R Tech Talk 11 May 21st, 2012 11:16 PM
removing a stuck bolt? alex.s General Motorcycling Discussion 27 April 5th, 2012 04:38 PM
