Old August 20th, 2017, 03:56 PM   #1
daverdfw
Motorcycle(s): 2009 Ninja 250
Need help adjusting clutch cable
So I had a lowside, and in fixing my clutch lever it noticed when I have the bike on stands and put it in first gear with the clutch engaged the rear wheel would spin. I tried all types of adjusting on the clutch cable no dice. So I order a new cable. Install it, its better, when I put it in 1st gear the rear wheel spins, when I stop it with my hand, it stays stopped.
Is this how it should work? Am I just an idiot with the adjustments? I read the service manual, and there is the correct amount of slack. Thanks!
according to this thread, this is normal?
https://www.ninjette.org/forums/showthread.php?t=90003
daverdfw is offline   Reply With Quote
Old August 20th, 2017, 04:39 PM   #2
jrshooter
Motorcycle(s): ninja 300
your ok with wheel spin. make sure your lever free play is adjusted at the tightest spot, check freeplay through the whole range of steering.
Old August 20th, 2017, 04:44 PM   #3
daverdfw
right now its really tight, I guess I need to take the clutch lever adjuster and put it in and see if that gives me more play. the bottom adjustment doesn't seem to do much
Adjusting clutch. ZeroGravity360 2008 - 2012 Ninja 250R Tech Talk 16 May 21st, 2016 04:40 PM
Help please!!! Clutch cable JayJay 2008 - 2012 Ninja 250R Tech Talk 5 August 6th, 2015 07:54 AM
Adjusting Throttle Cable - Barrel adjusters and Throttle body adjusters are maxed out theob 2008 - 2012 Ninja 250R Tech Talk 10 July 19th, 2012 05:01 PM
Clutch Cable atomicrm 2008 - 2012 Ninja 250R Tech Talk 2 December 17th, 2011 12:22 PM
Help on Clutch Cable kashun84 2008 - 2012 Ninja 250R Tech Talk 6 March 31st, 2011 08:55 PM
