August 28th, 2017, 08:49 PM | #1 |
Join Date: Aug 2017 Motorcycle(s): 2009 Ninja 250R Posts: 3
Worth to repair?
Hi all, I'm hitting up all the Ninja 250 forums for some help with my crashed 250.
Long story short, here's the list of damage to my bike: 1. Misaligned forks/bent fender support (as you can see from sidemarkers) http://i.imgur.com/mmDLJBq.jpg http://i.imgur.com/V96PdcK.jpg 2. Passenger seat frame bent/seat lock bent and keyhole seems misaligned http://i.imgur.com/W5FuoGv.jpg http://i.imgur.com/oLaj200.jpg http://i.imgur.com/MtAjZEB.jpg 3. Front seat plastic screw hole sheared, does not line back up (unsure if seat warped or if frame bent) 4. Most of my fairings, turn signals, tail light assembly, mirrors #2 and #3 worry me the most because it leads me to believe my frame may have been bent. What are your thoughts and what can I DIY to fix some of these? Thanks! |
August 28th, 2017, 09:00 PM | #2 |
bent frame bent wheel bent motor mounts
cost me 600 dollars to get straightend now its straighter than factory. |
August 28th, 2017, 09:58 PM | #3 |
Nice thing about steel is it can be cold-set. Find qualified shop that can bend frames and has jigs to check alignment.
August 28th, 2017, 10:45 PM | #4 | |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
Bill
Insanity: doing the same thing over and over again expecting different results each time. |
August 29th, 2017, 08:15 PM | #5 | |
you need the swing arm pivot 90 deg to the head stock, every thing else is just a bonus. |
August 29th, 2017, 08:31 PM | #6 |
Thanks for the help guys. Best case scenario, I bend back the passenger seat frame and it fits. What I don't want is for costs to rack up quickly since I did not pay very much for the bike to begin with.
Unfortunately, buying a new frame is out of the question given the cost. If the frame really is bent from the tail all the way to the front seat, there's no real way for me to bend it back is there? Is there a DIY way to check if my frame is still straight? |
August 29th, 2017, 08:42 PM | #7 |
You have to be creative, and use strings and squares and levels, etc.. I straightened my DT100 frame this spring by making a fixture to bolt the head tube to a beam in my shop, getting it vertical with a level, and bending the frame until the swing arm pivot was horizontal. Things fell into place pretty well after that. I left the engine in for that, because I knew if I took it out and bent the frame, it would be likely that the engine would no longer fit.
August 29th, 2017, 09:46 PM | #8 | |
Thanks again all! |
[tilted horizons] - A Job Worth Doing is Worth Doing Twice | Ninjette Newsbot | Motorcycling News | 0 | July 17th, 2015 10:20 AM |
Fairing repair | sidekick10121 | 1986 - 2007 Ninja 250R Tech Talk | 8 | March 17th, 2014 04:53 AM |
[topix.net] - Joe's Scooter Repair: Not limited to just scooters, they also repair AT | Ninjette Newsbot | Motorcycling News | 0 | August 12th, 2012 08:30 PM |
How do I repair a fairing? | PlaneGuy | 1986 - 2007 Ninja 250R Tech Talk | 14 | October 10th, 2011 05:40 AM |
Anyone know how to repair Fiberglass?? | ichibunkid.206 | Off-Topic | 4 | June 16th, 2011 02:29 PM |
