Old March 11th, 2019, 05:16 AM   #1
ford4x4302
Motorcycle(s): 08 ninja 250
Can't get 08 250 to run on both cylinders
I got a 08 250 that didn't run/ was sitting with gas in it for a year or two I cleaned the tank out cleaned the carbs and it fired up but I can't get it to run right I had the carbs apart 10 times now and still only runs on the left cylinder right cyl will only fire every now and then I have good compression on both cylinders and looks like good Sparks at the plugs both carb are opening as I apply throttle vacume seems good I checked the valve clearance exhaust are at .008 and the intakes are at .007 I tryed to swap the coils that didn't do anything I swapped the diaphragms in the carbs that didn't do anything and I put new plugs in it and still can't get it to run right .......any thoughts ?
ford4x4302 is offline   Reply With Quote
Old March 11th, 2019, 05:31 AM   #2
ducatiman
ducatiman's Avatar
loosening the drain valve on the RH carb...is fuel present?
Note, a couple ounces will drip if bowl is, in fact, full. Have rags or a catch cup under the carb when performing this.
So, fuel reaching RH carb,....yes or no?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 11th, 2019, 05:41 AM   #3
ford4x4302
Yes fuel is getting to both carbs if you open drain fuel will come out of both
Old March 11th, 2019, 05:47 AM   #4
ducatiman
ducatiman's Avatar
what methods you using to clean carb circuits?
you remove epa anti tamper caps on pilot screws?
Custom Carb Service
Old March 11th, 2019, 06:18 AM   #5
What was compression numbers on both cylinders?
What vacuum readings did you get for both? Where was it measured?
How did you test for spark? Exactly same for both?
What’s voltage at each coil’s supply terminal?
Old March 11th, 2019, 06:50 AM   #6
ford4x4302
Off the top of my head I don't know but I wrote it all down when I get home from work I will get all my readings and where should I be taking vacume readings from
1 carburetor for 2 cylinders , 1988 Ninja 250 juliusmichaelhonrada 1986 - 2007 Ninja 250R Tech Talk 2 June 3rd, 2016 08:32 PM
