Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old August 18th, 2014, 01:36 AM   #1
ninjanewby
Motorcycle(s): Ninja 300
fuel gauge query
It's only happened to me twice. But the full light was flashing. I know that indicates low level get to a petrol station ASAP! But how many kilometers can u go before it runs out?!? Just wondering...... Not planning on trying it out either.
ninjanewby is offline   Reply With Quote
Old August 18th, 2014, 08:58 PM   #2
The last bar should start blinking when there are 0.9 US gallons left in the tank, at least according to the manual:
If you don't have a copy of your owners manual, there is a sticky thread at the top of the 300 tech section.
Old August 19th, 2014, 04:35 AM   #3
ninjanewby
Does anyone know the mpg whilst not going really hard? E.g. When the ECO is registering.
Last futzed with by ninjanewby; August 23rd, 2014 at 08:37 PM.
Old September 8th, 2014, 10:31 AM   #4
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I get 60mpg+
Old April 25th, 2015, 09:51 PM   #5
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Not to bring back an old topic....but I just experienced the fuel gauge blinking for the first time with 1 bar left. I normally fill up once I hit one bar (not blinking). It would just suck big time if I have to push the bike or wait for a buddy to bring me gas. *walk of shame* (been there, done that on previous bikes).
Anyways, does that last bar ever disappear before we run completely dry? Or is that last bar blinking the last warning we get before we run out of gas?
I'll be interested to see how much gas will go in the tank tomorrow. I only rode about 5 miles with the fuel gauge blinking.
I'll update you guys when I fill up tomorrow morning.
Riding it like I financed it.
Old April 30th, 2015, 08:37 AM   #6
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Not to mention it damages the bike having it run out of fuel.
Also, If i'm good to the bike I get 70mpg (eco button on 24/7) my usually mix of nice riding and slight aggression nets me about 65mpg usually. And If I go crazy i'll get high 50's low 60's.
Gotta love these bikes!
Be careful. Remember you are
invisible
Old May 19th, 2015, 11:06 AM   #7
APEmike
Motorcycle(s): 2014 Ninja 300
When my 2nd to last bar turns of, 1 solid bar remaining, it only takes 2.6 gallons to fill up. I think my gauge is off...
Old May 19th, 2015, 11:20 AM   #8
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Yup. Sounds off to me. How many miles were ridden? I normally fill up around the 200 mile range and still only takes 3.5gal.
Old May 19th, 2015, 11:48 AM   #9
How high are you filling up before stopping the pump?
Old May 20th, 2015, 04:50 PM   #10
APEmike
158 miles. 62.5 MPG pushing 75-85 on the 14 speedway in SoCal between Lancaster and Newhall.
The only time I pay attention to how much goes in and milage is when I leave for a long trip, and want to figure milage. I fill it right to where it touches the bottom of the filler guide thingy (technical term) on a level surface so I can be consistant. Otherwise I let the pump stop it so I dont have to worry about expansion and the charcoal filter.
Old May 20th, 2015, 05:11 PM   #11
[citation needed]
Sure about that, Danny?
Old May 21st, 2015, 09:11 AM   #12
APEmike
[citation needed]
It *can* damage the bike.
For injected bikes getting air in the line after the pump makes it run lean. Depending on the situation there could be no issues or detonation/heat issues. It can also cause the pump to overheat and shorten its life because its not immersed in a cooling liquid (fuel)
For carbed bikes, as fuel supply runs lower and lower the fuel pressure will drop due to being gravity fed. Less fuel = less weight = less pressure.
That being said on a street driven 250 or 300, chances of bad things happening to the engine are fairly small...
Old May 21st, 2015, 03:34 PM   #13
You're forgetting that if the fuel pump runs dry, the engine will stop and the whole system will experience a no-run condition and everything shuts down. It won't run dry forever and burn itself out, which takes quite a while for an OE-quality fuel pump, not a couple seconds. Also, it sits in the fuel level, so it's always primed after you add more gas to it when it has run dry. So all you have to do to get back to regular, undamaged operation is cycle the key on and off to cycle the fuel pump a couple times and pressurize the system. I also would hazard a guess that a significant change in fuel pump amperage due to overheating or sucking air is cause for a no-run condition and would throw a light on the dash, at the very least.
Yes, I know well how head works, but the effect in this situation is minimal because vacuum from the carbs sucks fuel in. Suction from Venturi effect pulling fuel through the jets >>>> fuel supply head. It's only supplied by gravity, not fed and metered by gravity.
I was more asking for Danny to think his statement through and justify it, rather than just accept and regurgitate a random "fact" he read somewhere on the Internet. He should have said there was a risk of damage from running empty, not that the bike WILL GET DAMAGED if it runs out of gas.
Old June 23rd, 2015, 03:46 PM   #14
reggae5
reggae5's Avatar
Motorcycle(s): 2013 Ninja 300
Had a chance to experience the blinking fuel light just a couple days ago. And I was on back roads so I went about 10 miles or so with the light blinking ( bar never did disappear ) parked it at home for the night. Then the next morning went out to the bike wondering if it would start up and it did and I drove about 1.5 miles to the gas station and it took 3.558 gallons. Does make one wonder if you drove carefully and the light started blinking if you could get 60 more miles mmm?
reggae5 is offline   Reply With Quote
Old July 31st, 2016, 08:35 PM   #15
Tim Fox
Tim Fox's Avatar
Motorcycle(s): 2014 Ninja 300 SE
:green moto:
Tim Fox is offline   Reply With Quote
Old July 31st, 2016, 08:36 PM   #16
Tim Fox
Tim Fox's Avatar
There is a eco button?
:green moto:
Old August 1st, 2016, 06:25 PM   #17
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Yup. It's right next to the NOS button. Make sure you press the right one.
Replace Fuel Gauge with Fuel Light? Proteus 2008 - 2012 Ninja 250R Tech Talk 8 December 2nd, 2014 08:33 AM
My video on how to fix the fuel sender for your fuel gauge Klint 2008 - 2012 Ninja 250R Tech Talk 1 November 2nd, 2013 09:04 PM
Fuel gauge (FI version) crackez 2008 - 2012 Ninja 250R Tech Talk 4 May 23rd, 2013 05:51 AM
Fuel tank/Fuel gauge issues coolcatjames 2008 - 2012 Ninja 250R Tech Talk 10 August 23rd, 2012 06:25 PM
fuel gauge shellneil General Motorcycling Discussion 8 November 1st, 2009 02:26 PM
