Old January 24th, 2016, 06:31 PM   #1
skip
skip's Avatar
Motorcycle(s): 2009 250r
dead battery
My battery is apparently dead it's been sitting for a minute and is dead now what kind of charger do I use to charge it and where can I get one thanx bros
Posted via Mobile Device
skip is offline   Reply With Quote
Old January 24th, 2016, 06:33 PM   #2
Battery Tender Jr at where ever it's the cheapest, try walmart.
Old January 24th, 2016, 06:38 PM   #3
skip
skip's Avatar
How long do i charge it for and thank u
Old January 24th, 2016, 09:12 PM   #4
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Battery tenders are slow but because of that you can just leave it plugged in forever without hurting the battery. When I accidentally kill my battery I bump start it and ride around for about 10 mins first to get a strong initial charge going then I toss it on the tender over night or all day at work. If your battery is totally in my experience a tend has a hard time getting that initial charge going. I've plugged in over night with no bump start before hand and still nothing the next morning.
Bump starting with a dead battery will be harder then a good battery but it will always start eventually. Longest it's taken me was 10 runs in cold weather but those first 9 probably generated enough juice to make that tenth run work.
Old January 24th, 2016, 09:35 PM   #5
Hey skip,
Assuming a battery that can take a charge well, after about 8ish hours on the tender, it should start. And.... I always forget to specify which one to buy, you want the 2amp one. And yes, if the battery has 0% charge, a tender has a harder time getting it charged, but in my experience, it will eventually overcome it and charge it. I have waited 3 days before during the off season. But during the riding season, I just push start it or jump it off a NON RUNNING (engine off) car.
Old January 25th, 2016, 07:06 AM   #6
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
I had to purchase two new batteries recently. I have tenders for all my bikes but still seem to lose a battery every other year or so. I like the Battery Tender Jr models but I have a couple cycle gear specials that have worked just as well. They went on sale for like $15 a piece or so and grabbed a couple.
Old January 25th, 2016, 07:58 AM   #7
BernawanFR
BernawanFR's Avatar
Motorcycle(s): Kawasaki Ninja 250R 2011
I once had a dead battery (kill switched it and forgot to turn the key to off for a night, silly me) bike didn't even start but then I took the battery out to the shop, paid like $2.5, picked it up one day after, put it back on, and it worked just like a new battery.
I know I'm not aware of the situation in states but I think it's cheaper if you take it to the shop rather than buying a charger (less money and time will be spent), or am I wrong?
BernawanFR is offline   Reply With Quote
Old January 25th, 2016, 08:06 AM   #8
HoneyBadgerRy
HoneyBadgerRy's Avatar
Hey skip,
I have (ok my dad has and I witnessed) charged a battery backwards with a battery tender accidentally, it tried to start the jet ski backwards, so we (he) drained the battery and charged it correctly, it actually had a decent life after that.
Old January 25th, 2016, 07:57 PM   #9
netdobeiras
Motorcycle(s): 2004 kawasaki ninja 250
Some autozones will charge the battery for free...... like mine
netdobeiras is offline   Reply With Quote
Old January 27th, 2016, 08:37 PM   #10
MBZuki
Motorcycle(s): Depends on the month
From my experience most batteries (at least factory FMBs or Yuasas) have the charge rate and duration marked on the battery.
With a carb'd machine you might get it bump-started. FI if the thing is dead dead I think you're pretty much hosed; might not be enough power to fire the injectors/ecu/etc., at least in cars I've seen that.
I have seen the BTJ around lots but I use Noco Genius chargers for the four and two wheeled machines. They make a G1100 that serves as a nice maintainer/trickler for big car/truck batteries and a suitable normal charger for the powersports stuff.
MBZuki is offline   Reply With Quote
Old January 27th, 2016, 10:11 PM   #11
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
I beg to differ. I had the same situation with my ER-6n before. The only thing is, you need to push harder. Or someone else is doing it for you while you are comfortable sitting on your bike... lol.
Abu_Mishary is offline   Reply With Quote
Old January 29th, 2016, 11:34 AM   #12
RickM
Motorcycle(s): 2000 EX250
My ninja 250 won't run without some charge in the battery. If the battery is flat, it can't be bump started at all. Most of my other bikes will run without a good battery once it's bump or jump started.
Btw, if you have completely discharged the battery, it's safer to get a new battery and maintain it with a tender if not ridden frequently or only short trips.
Even if you manage to revive the current battery, it's going to fail without warning eventually. Small batteries like in the ninja 250 will seem to work fine one start and be completely dead next attempt when they fail. No warnings like dim lights, slow cranking etc before they completely fail. This was my experience
RickM is offline   Reply With Quote
Old January 29th, 2016, 12:16 PM   #13
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Especially true with absorbed glass mat (AGM) "maintenance free" batteries.
Less prevalent with old-school flooded lead acid (FLA) batteries.
Old January 30th, 2016, 06:51 AM   #14
sh123469
Motorcycle(s): EX250, Suzuki Savage, 76 Goldwing restoration project, 71 CB350, 73 Yamaha GT1,
I had an AGM that did that too. One day it started the bike great. Next day it just clicked and did nothing. Tried charging, would turn the bike over for about 3 seconds then was dead. New battery, no more problem.
sh123469 is offline   Reply With Quote
Old January 30th, 2016, 07:26 AM   #15
DaBlue1
DaBlue1's Avatar
https://www.ninjette.org/forums/show...47&postcount=4
Kawasaki recommends using a 1.5 Amp Automatic Charger. Battery Tender Jr. output is .750 amps. Schumacher makes a perfect charger designed for small batteries such as used on motorcycles. It can be purchased at Walmart for about $21.00
The Schumacher Model XM1-5 maintains both 6 and 12-volt batteries, keeping them at full charge using float-mode monitoring.
Old January 31st, 2016, 11:32 PM   #16
corksil
Motorcycle(s): A lot.
^^ same experience with an AGM battery. Bike was fine for a ride, and after sitting overnight -- completely dead. No lights, no clicks, nothing.
Tested with multimeter, diagnosed dead battery. Replaced and back on the road.
Failed battery wouldn't take a charge and finally took it apart (NOT RECOMMENDED) and found that a plate had shifted and caused internal failure.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy.
Old January 31st, 2016, 11:34 PM   #17
RickM
Ah.. so it's more of an AGM battery thing. Yeah the one I experienced this on was an AGM battery.
Dead battery? Alex 2013 - 2017 Ninja 300 Tech Talk 30 August 30th, 2015 05:45 PM
Dead battery, could you please suggest anything?? bloodline 2008 - 2012 Ninja 250R Tech Talk 14 May 6th, 2015 07:13 PM
Possible dead battery roc0487 2008 - 2012 Ninja 250R Tech Talk 22 April 14th, 2015 01:37 PM
battery dead? ProdigyRacingLA 2008 - 2012 Ninja 250R Tech Talk 17 March 14th, 2012 08:42 PM
Less than 4k mi. on '09 ninjette . Battery already dead 00v_Lucky 2008 - 2012 Ninja 250R Tech Talk 10 June 17th, 2009 06:21 AM
