October 5th, 2011, 03:22 PM | #1 |
Fixing something thats not broken - Drop-in Air Filters
I am not looking for a performance increase (though I would not be against it persay) nor am I looking to do any carburator work.
Bike is currently shimmed 2 washers w/ snorkel out and stock exhaust. I like it the way it is BUT the stock air filter has gone through a few clean/oil cycles that is starting to break down. I thought that since I have $10 promotional credit and some amazon rewards points that I'd try out a k&n drop-in filter (purchased for $2) expecting little to no changes in performance. NOT TRUE, popped it in and the entire powerband felt flat. I'm assuming that its because the K&N flows a tad more air and hence leaned out everything. So my question is what to do what to do? I'll most likely return the K&N but what should I do with the stock filter replacement issue? |
October 5th, 2011, 03:48 PM | #2 |
ModMy250.com
buy a stock replacement? Try putting the snorkel back in with the K&N?
The www.ModMy250.com guy |
October 5th, 2011, 03:55 PM | #3 | |
I think I'll just go look for a stock replacement and be done with it. The reason I went with the K&N was because I had some cleaner and oil for the K&N back when I used it for my car that I no longer have. Does the pipercross foam filter flow more/less air than stock? Maybe I'll try that just for kicks too. |
October 5th, 2011, 04:02 PM | #4 |
ModMy250.com
Foam filters are not a good idea. They allow more dirt to entire the engine. Some guy did a comparison with a vacuum with different filters and found the foam type to not work very well. It's not scientific, but did show a healthy amount of dirt being ingested.
October 6th, 2011, 08:15 AM | #5 | |
October 6th, 2011, 09:03 AM | #6 | |
As with anything you will always have those who like other products and may have good arguments for their choices, however I think the jury is still out on which type filter is the absolute best. I believe that each type of filter has it's advantages and disadvantages depending on the application and design. You may just have to check it out yourself. |
October 6th, 2011, 09:43 AM | #7 | |
October 6th, 2011, 01:03 PM | #8 |
ModMy250.com
Wait, you originally said that it flowed too much air causing a lean condition on the entire RPM band. Now you want another filter that will do the same thing?
October 6th, 2011, 03:33 PM | #9 |
I suspect the lean condition was caused by the fitment of the K&N not the extra flow that you get from the filter itself. I am currently running a little rich and so I assumed that a little bit more flow would make it better but the K&N drop-in is rubber and was pushing the cover open. Who knows, I could be wrong and in the end I'd still need to mess with the carbs. I havent entirely decided yet.
October 7th, 2011, 08:53 AM | #10 |
ModMy250.com
I don't see how the fitment of the filter will affect your AF ratio. My bike has a K&N and is jetted properly too. Maybe it's time to jet your carbs?
October 7th, 2011, 09:09 AM | #11 |
The K&N was a bit difficult to close the cover to the airbox. Looks like a possible leak meaning wayyyy more airflow than necessary leading to a lean condition. Atleast that's my assumption. In anycase, I guesss I could jet my carbs but I'm not really interested in fiddling with it yet.
October 7th, 2011, 12:21 PM | #12 |
ModMy250.com
Did you ever compare the K&N to the old one you had to see if the dimensions were a little off?
October 7th, 2011, 10:06 PM | #13 |
Didnt have to... It's not that it didnt fit, it was just such a tight fit that if you dont really snug it in all the way, the cover gets pushed out a little and leaves a crack. Doesnt matter. K&N is already returned. No biggy. If I go with any other aftermarket air filter, I might need to add a shim or something regardless. No need to figure out anything about the K&N anymore. Thx anyways.
October 8th, 2011, 05:32 AM | #14 |
Join Date: Oct 2009 Motorcycle(s): ninja250r 2009model Posts: 30
maybe ur putting the k&n filter in a wrong way and having trouble inserting the knn filter is u might not used the lubricant that it has with the filter when u bought it...im using k&n filter also works fine with me....
October 8th, 2011, 09:34 AM | #15 | |
Regardless, I wasnt in the mood to deal with either issue and so I left it at stock... for now. I figured, if I return it now, I can use the money again later to buy something else. It's not like I lose the promotional credits if I return it. |
October 8th, 2011, 05:09 PM | #16 | |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
I also have a K&N filter and I cannot push it in anymore... also after my bike sitting all winter, this spring I noticed when I took the air filter COVER off (3 bolts) the cover itself was "Warped" slightly, cuz the K&N filter pushes back against it. I removed/shaved Off some of the plastic (1/16th") in the middle of the cover, so the K&N dont push against it! |
October 9th, 2011, 02:25 PM | #17 |
So, where's the reverse?
The rubber border of the K&N is what pushes up against the cover. By design, the OEM filter does as well but the difference is that being foam, it has more give. If you look on the inside of the cover, there is a raised lip or edge where it pushes against the filter to form a seal. I suspect that any foam type filter would fit fine since the cover was designed for that type.
BMC makes a filter that is high-glow and is the wired cotton gauze type similar to the K&N. The difference is that the BMC has a foam border around the filter and I assume this was done by design to fit against the air filter cover without pushing against it like the K&N. |
Back to fixing the broken beast. | itslocfoo | 1986 - 2007 Ninja 250R Tech Talk | 56 | January 3rd, 2014 05:36 PM |
Air Filters | 102dalz | 2008 - 2012 Ninja 250R Tech Talk | 2 | September 18th, 2013 06:42 PM |
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su | Ninjette Newsbot | Motorcycling News | 0 | June 11th, 2012 06:00 PM |
Aftermarket Drop in Type Air Filters | DaBlue1 | 2008 - 2012 Ninja 250R Tech Talk | 11 | April 7th, 2011 05:37 AM |
fixing broken fairing??? | Greg_E | 2008 - 2012 Ninja 250R Tech Talk | 8 | August 23rd, 2009 07:47 AM |
