Old June 21st, 2015, 05:51 PM   #41
Ghostt
Ghostt's Avatar
I know I'm interested in the outcome
violente et ignorantia
ZX-2R BLOG
Old June 21st, 2015, 08:03 PM   #42
Mitchell_hs
Motorcycle(s): 04 Ninja 250R
Sorry guys I have only just now seen the replies! But I took it to the shop and they've had it for about 2 weeks now. They creamed the tank for me. It has a little rust in it. As far as the bogging down and everything, they rebuilt the carbs and they say so far it runs like new. The did an oil change and changed the filter. And I also asked them to look at something else the bike was doing. When it was running good I could ride for about 20 mins then it would shut off and wouldn't crank until I waited a couple minutes. And would do that every 3 minutes after that. So they told me it was some type of sensor. And that they were gonna rewire it for me. I was thinking it was the ignition box but they didn't think so. But either way the said it runs great now. I'm picking it up this week sometime. They haven't given me an exact price yet, but the estimate is $260. Is that good or bad?
Mitchell_hs is offline   Reply With Quote
Old June 21st, 2015, 09:26 PM   #43
Ghostt
Ghostt's Avatar
The bike shutting off, does it happen when it's warm out?
Sounds like the tank vent, you need to disassemble the gas cap and remove the two small red diaphragms
IMHO this should be done regardless, because sooner or later the small diaphragms gets old, dries out, and sticks shut.
ZX-2R BLOG
Old June 22nd, 2015, 03:30 PM   #44
Mitchell_hs
It happens no matter what. I do need a new gas cap but I'm not sure that's it. It definitely has a wiring problem. But I'll definitely get that done. You think if I just got a new gas cap if that would help?
Old June 22nd, 2015, 03:32 PM   #45
Ghostt
Ghostt's Avatar
No new gas cap, just remove the small red diaphragms as I stated earlier, you'll be better off in the long run.
Have you inspected and cleaned the spark plug caps? This is a very overlooked issue.
ZX-2R BLOG
Old June 22nd, 2015, 08:20 PM   #46
Mitchell_hs
Well I have to get a new gas cap anyways. Somebody drilled a hole into my key slot on my gas cap and now it won't close.
Old June 22nd, 2015, 11:36 PM   #47
Ghostt
Ghostt's Avatar
Well that suxs, well when you get the replacement one, used? Do the modification.
ZX-2R BLOG
Old June 23rd, 2015, 12:27 PM   #48
Mitchell_hs
I sure will man. I really appreciate all the help!
Old June 23rd, 2015, 04:48 PM   #49
Ghostt
Ghostt's Avatar
No worries, glad to help, hope it all works out for you, keep us posted.
ZX-2R BLOG
Old June 25th, 2015, 08:18 PM   #50
Mitchell_hs
I will man! Everyone here was very helpful!
2005 Ninja 250 idles but bogs down after throttle enkhamar 1986 - 2007 Ninja 250R Tech Talk 9 May 9th, 2014 12:14 PM
Bike bogs down at 9K stubshaft 2008 - 2012 Ninja 250R Tech Talk 7 May 5th, 2014 05:41 PM
bike loses power and shuts off on freeway realmess 2008 - 2012 Ninja 250R Tech Talk 14 March 18th, 2012 03:37 PM
Engine Bogs and dies? xlatinox 1986 - 2007 Ninja 250R Tech Talk 4 February 19th, 2011 12:24 AM
Ninja 250r power commander snowlife 2008 - 2012 Ninja 250R Tech Talk 15 April 20th, 2009 06:29 PM
