August 5th, 2013, 08:11 AM | #1 |
Join Date: Jul 2013 Motorcycle(s): 2005 Ninja 250 Posts: 7
Changing Oil Without Replacing Filter
I've got nearly no oil in my engine but I want to get the oil and filter changed at a shop. But the bike shop is 10 miles away. The previous owner changed the filter 400 miles ago. Is it okay for me to change the oil without replacing the filter?
2 weeks ago, I was just adjusting my bike while it was off and I dropped it on its side. Engine oil leaked out of it but I didn't think it was engine oil and just shrugged it off. Now I'm looking at the sightglass and it looks like my engine desparately needs oil. I don't have a filter on-hand and it'll take ~5 days for one to ship from Amazon but I'm having my motorcycle shipped across the country at the end of this week. I want to get the oil + filter done at a shop but I don't want to ride there and damage my bike some more. I bought the bike a month ago and took it to a bike shop to have it looked it at. The mechanic said that I had a leaky valve cover gasket but that I could hold off on getting that repaired. Do you guys think thats how the engine oil got out? Thanks! |
August 5th, 2013, 08:14 AM | #2 | |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Hey Unregistered never go faster than your brakes can be applied... |
August 5th, 2013, 08:17 AM | #3 | |
MOTM - Mar '13, Jun '14
August 5th, 2013, 08:48 AM | #4 | |
All you need to do is re-fill the engine with some oil of proper viscosity. Check these links out: http://faq.ninja250.org/wiki/How_do_I_check_my_oil%3F http://faq.ninja250.org/wiki/Oil_Change_Procedure You need to have the bike perfectly vertical and on both wheels for refilling the oil, which level should reach half way the glass visor on the right side of the engine.
August 5th, 2013, 08:52 AM | #5 | ||
The bike needs to be held level on both wheels and not on the center stand. If the previous owner changed the oil 400 miles ago you shouldn't need to change it again. If your bike has no oil after 400 mile you have a terrible oil leak, which would be highly noticeable. Quote:
Unless you had a significant amount of oil leak out, you may just need to top the level off just below the high mark on the sight glass. recheck it the right way. Make sure you wipe any spilled oil off of the engine and exhaust. You may be able to pick up an oil filter at a local auto parts store. You don't have to buy one from a shop or online. have a look at the wiki. http://www.ninjette.org/wiki/Oil_Filters While you're at it, get an owner's manual to help you get familiar with your bike. |
August 5th, 2013, 09:20 AM | #6 | |
Oil filter crosses over with Honda filter | smokinsingle | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 19th, 2014 08:47 AM |
Is there a certain order on changing your oil and air filter on your bike? | jon.b.calderon | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 6th, 2013 09:23 PM |
Loss of oil and Air filter soaked in Oil | 08ninja250 | 2008 - 2012 Ninja 250R Tech Talk | 19 | August 9th, 2010 05:35 PM |
[webbikeworld.com] - Substitute Ducati Oil Filters - Changing the Multistrada Oil and | Ninjette Newsbot | Motorcycling News | 0 | October 26th, 2008 05:10 PM |
