Go Back   ninjette.org > General > Ride Reports
Old August 30th, 2011, 11:43 AM   #1
ninja_sleeper
ninja_sleeper's Avatar
Motorcycle(s): Red 2009 Kawasaki Ninja 250R
Bike Pushing.
Yesterday I ran out of gas a block away from the gas station. Got to pushin. Had to go up hill a little bit, and the whole time I was thinking of alex.s and how he pushed the sh** out of his bike a hell of a lot further than I did. I was pretty winded by the time I got to the gas pump. Thanks for the inspiration Alex!
ninja_sleeper is offline   Reply With Quote
Old August 30th, 2011, 11:57 AM   #2
Cuongism
Cuongism's Avatar
A block away? Just a suggestion for next time (hopefully there isn't a next time), you can always buy a Gatorade to drink and then fill that up with gas.
Or you can do what I do, show off some leg to cars driving by
Old August 30th, 2011, 11:57 AM   #3
Old August 30th, 2011, 01:14 PM   #4
I'd stop for both of you showing off leg
Old August 30th, 2011, 01:52 PM   #5
AeroXtasy
New 2-Wheel Addict
AeroXtasy's Avatar
Motorcycle(s): Blue 2009 250r Kawasaki Ninja
This was after switching on reserve, right?
AeroXtasy is offline   Reply With Quote
Old August 30th, 2011, 01:59 PM   #6
There's no reserve on the new-gen bikes.
Old August 30th, 2011, 02:06 PM   #7
AeroXtasy
New 2-Wheel Addict
AeroXtasy's Avatar
Thank god your telling me now, or I'd be in the same position the creator of this thread was in sometime! Lol.
I seriously didn't know that. Just seen people talking about reserve and assumed new-gen's were included.
Old August 30th, 2011, 02:07 PM   #8
ninja_sleeper
I left the reserve on
I believe there is, it's behind the panel on the left side, kinda where the idle is. You have to take off the panel to access it. It says PRI and ON. Unless that's not the reserve...
Old August 30th, 2011, 02:08 PM   #9
Read your owners manual. And go buy some gear.
Old August 30th, 2011, 02:09 PM   #10
Originally Posted by ninja_sleeper View Post
I believe there is, it's behind the panel on the left side, kinda where the idle you. You have to take it off to access it. It says PRI and ON. Unless that's not the reserve...
That's the petcock, but there isn't a reserve setting on the new-gens. On the pre-gens, there are 3 options (Prime/On/Reserve). The new ones are just Prime/On, with no reserve.
In return, we get a gas gauge to monitor the fuel, which the pre-gens don't.
Old August 30th, 2011, 02:10 PM   #11
prime != reserve
the ninja has off, prime, and on. same as my crazy aftermarket fzr petcock.
Old August 30th, 2011, 02:10 PM   #12
does that mean euro-jettes get a reserve tank?
Old August 30th, 2011, 02:13 PM   #13
ninja_sleeper
What is the petcock?
Old August 30th, 2011, 02:13 PM   #14
AeroXtasy
New 2-Wheel Addict
AeroXtasy's Avatar
I bought used, no manual. I'll download one now though.
As for the gear, I'll get on it soon. I won't ride it now past the next couple streets without any real gear besides my helmet.
Can you just set it to go ahead and use all of the fuel in the tank (like a reserve) by turning the petcock off?
Old August 30th, 2011, 02:19 PM   #15
What is the pet cock?
it's what you do in bed.
oh wait!
it's the thing on the bottom of your gas tank.
Old August 30th, 2011, 02:20 PM   #16
turning the petcock off means you don't get any fuel. turning it on means you will use all of the fuel in the tank.
Old August 30th, 2011, 02:21 PM   #17
Azhyen
ninjette.org Pirate
Azhyen's Avatar
Props to you Carrie! ~ 340lbs. is still moving 340lbs! Because of my hard riding on the freeway, I try not to go more than 180mi. between fill-ups, but somtimes you'll find yourself in a bind.
"She said I can't get a bike, so I dumped her."
Azhyen is offline   Reply With Quote
Old August 30th, 2011, 02:21 PM   #18
Nope - they just have a low fuel light.
It's that device at the bottom of the tank with those options (prime/on). It controls the fuel flow coming from the tank. Prime allows it to flow no matter what. On only allows it to flow when the engine is running (if it's working correctly).
There is no off setting. It's only Prime/On. Pic below...
Old August 30th, 2011, 02:23 PM   #19
no off?! i could have sworn every time i took my tank off i had to set it to off first...
Old August 30th, 2011, 02:24 PM   #20
ninja_sleeper
Alex, why is there that option? Is there a benefit to keeping it on or off?
Thanks. I did it for the stories.
oh wait!
Old August 30th, 2011, 02:28 PM   #21
There is no off. I feel I'm repeating myself a bit. Just On/Prime. It should stay at On at all times. The only reason to move it to Prime is if the engine is off, and you need to fuel to flow despite having no engine vacuum, primarily when you are trying to fully drain the tank.
Old August 30th, 2011, 02:34 PM   #22
Momaru
Momaru's Avatar
The prime/on option is there for trouble-shooting. The 'on' position is controlled by a vacuum valve. When the engine is operating correctly, it creates suction against the fuel line, which opens that valve and allows gas to flow.
"Prime" allows the gas to just drain down the tubes by gravity (I honestly don't know if it bypasses the vacuum valve or just forces it open). The catch is that if you leave "prime" set, you can flood out the carbs, filling them with too much fuel. It's useful for refilling the bowls after you've had them drained for carb work or storage. Or trying to intentionally drain the tank for one reason or another
To confirm, the new gens (or at least the '08) do not have an "off" or a "reserve" option. And our fuel gauge is unreliable at best. I'd rather have a reserve
On a related note, anyone know of a small spare gas container? Looking for ~1L. The 1 gallon tanks are just silly large.
+1 props to you Carrie, for pushin. I've walked my bike to the gas station before (and out of a couple ditches after some unintentional off-roading), it's a workout.
Proud member of the Blue Army
Old August 30th, 2011, 02:41 PM   #23
ninja_sleeper
Cool thanks. Why get a gym membership when you can just push your ninja around in circles?
Yea small gas tank would be nice. Also a small battery charger, too. One that can fit in a back pack. I sometimes leave my key on too long.
Old August 30th, 2011, 02:45 PM   #24
Mountain Research makes some nice ones. I don't know where I'd store it on the ninjette, though. They'd fit easily in a backpack, but carrying extra fuel in a backpack full-time seems like it would be overly uncomfortable/tiring. Links here:
http://www.nextag.com/fuel-bottle/stores-html
Old August 30th, 2011, 03:05 PM   #25
Havok
Internet Slut
Havok's Avatar
Motorcycle(s): 04 FZ1, 07 FZ6
so is there an off position on the new gens
Havok is offline   Reply With Quote
Old August 30th, 2011, 03:06 PM   #26
setasai
setasai's Avatar
I've considered lugging around fuel bottles but it's not that often that you need it. I mean how often are you going to push your tank till it gets to 100% empty. It's not that hard to stop anywhere between 150-200miles. There has to be a gas station somewhere within 50miles worth of riding.
For those emergencies, I pay AAA just for this. I think with the cheapest membership you need to pay for the fuel but what's $4 for another 50mile range?
Old August 30th, 2011, 03:06 PM   #27
Momaru
Momaru's Avatar
The battery Tender Jr fits the bill for the charger. It's on sale @ CheapCycleParts atm, around $26. You'll need to install a plug (included) directly onto the battery to charge it, but it's a permanent plug that you can use for other things when you're not topping off the battery (like heated clothing, phone charger, etc). Also comes with alligator clips to charge other batteries. Get the 12V model.
Old August 30th, 2011, 03:06 PM   #28
setasai
setasai's Avatar
Really? No there is no off position.
Old August 30th, 2011, 03:24 PM   #29
Momaru
Momaru's Avatar
On the way back from the Dragon's Tail rally, I was at 198mi and my gas gauge said I had better than 1/4 tank left. I was coming up to an exit, but decided to carry on since I had plenty o' gas left, so sayeth the gauge.
I hadn't even finished looking @ the gas gauge before I began to lose power and not in a subtle way. Initially thought the rear tire had gone flat on me, so I pulled the clutch and just rolled to a stop on the on-ramp. Took a look; back tire was fine, but popped the gas tank lid. There was a lil more in the tank, but I had to shake her side-to-side to get it in the fuel lines with the petcock on "prime," to fill the carb bowls.
All that said, I think I agree about that spare fuel container, perhaps not worth carrying. The 11oz would be easy to carry, but even at 65mpg, that's just a little over 5mi of extra gas, if you can get it to feed. On the other end, the 33oz gives ~15 extra miles (again assuming 65mpg), but that's a big bottle to carry around everywhere. Maybe if one has permanent saddlebags, but I'm not such a person.
Old August 30th, 2011, 03:29 PM   #30
ninja_sleeper
It was kind of a strange coincidence. I didn't have any cash on me and lost my bank card, had to be at work at 8am before the bank opened. Made it to the bank after work.... but the gas station.
I like the idea of buying a Gatorade, drinking it then putting gas in it. I wonder if they would let you do that.
Old August 30th, 2011, 03:35 PM   #31
Momaru
Momaru's Avatar
There's usually signs on gas pumps telling you not to put gasoline in anything but an 'approved' container. I honestly don't know how a gatorade bottle would hold up to that kind of chemical. That said, I happen to have some spare gasoline (from emptying my carb bowls) and a gatorade bottle lying about. I'll go see what happens.
If you do decide to go that route, make VERY sure you rinse that out before you use it. The large amounts of sugar in Gatorade (and most other drinks) will do bad things to your fuel system. Ever heard of pouring sugar in someone's gas tank? Very expensive prank to pull.
I'd lean towards using an aluminum water bottle myself.
Old August 30th, 2011, 03:42 PM   #32
bluepoof
bluepoof's Avatar
Motorcycle(s): 2007 Ninja 250, 2002 Yamaha XT225
My husband may have used a bottled water bottle to bring fuel to me while I was stranded on the side of the road once. The container may have held the gasoline just fine for the mile or so back to me from the gas station.
This is all hypothetical, of course, it being illegal to transport gasoline in a non-approved container.
FWIW, I've also stored bad/old gas in empty gatorade containers for months at a time before getting to the hazardous waste drop off. It's fine.
www.bluepoof.com
bluepoof is offline   Reply With Quote
Old August 30th, 2011, 03:49 PM   #33
Momaru
Momaru's Avatar
Hehe, good to know. I just decided to try it, kinda expecting the gasoline to eat through the bottle quickly. Guess I might be waiting a while, huh?
I keep my spare/bad gas in a small steel paint can
Old August 30th, 2011, 03:50 PM   #34
Gasoline isn't that corrosive, and many vehicle tanks are made out of different types of plastic nowadays anyway. I think you'll be waiting a *very* long time.
Old August 30th, 2011, 04:00 PM   #35
just don't use that stryrofoam icebox.
Old August 30th, 2011, 05:44 PM   #36
algerath
algerath's Avatar
Motorcycle(s): 2010 ninja 250
I don't have a pregen to look at anymore, anybody know if you could put a pregen on/off/res petcock on a newgen? I do realize it would not be easily accessible behind the side panel.
I have thought a reserve like I had on my pregen would be nice. My fuel gauge works well, I must be one of the lucky ones, I know I have .8-.9 gal left when I hit the red line. It would just be a nice little backup to have that res.
algerath is offline   Reply With Quote
Old August 30th, 2011, 05:52 PM   #37
Cuongism
Cuongism's Avatar
The pre-gen petcock won't work and will be absolutely useless for you if it did. There isn't a "reserve" tank or anything, but the pre-gen petcock has two pipes that it draws from. Switching to the reserve just draws from your shorter pipe.
On the new-gen, there's a fuel gauge that let's you know when you're nearing the end. Best bet is to use your trip meter and know how many miles your tank can go (ie I fill at 190 since 210 empties it).
Old August 30th, 2011, 06:19 PM   #38
algerath
algerath's Avatar
I understand how it works, I know there is no reserve tank. If you take the petcock off of a pregen will it physically mount to the hole in a new gen tank? If so it will work exactly the way it worked on the pregen! If you switch the lever on the petcock to res It will flow fuel from the short straw the same no matter the age of the tank it is in or the presence of a gauge on the dash, I can determine for myself if this will be useful or not.
I do realize there is a fuel gauge on my motorcycle, if you review my post you may notice I even commented mine works well. I also realize there is a trip meter, I use it regularly. I also used it on my pregen when I had it. I only used reserve on my pregen a couple times, but it did come in handy.
Now back to my question does anyone know if the pregen petcock will physically mount to the newgen tank?
Old August 30th, 2011, 06:23 PM   #39
The tanks are different. The "straws" are part of the tank, not part of the petcock assembly. I'm confident someone could work up a system to modify a new gen tank to provide a reserve feature, but it would be more work than just attaching a pre-gen petcock.
Old August 30th, 2011, 06:31 PM   #40
algerath
algerath's Avatar
Are you sure ? I am pretty sure I remember the straw being part of the petcock assembly on my pregen. It is possible I am confusing it with another old bike I had, as I had the petcock off on both.
pushing a sumo to the limits alex.s Videos 12 October 1st, 2014 03:33 PM
[motogp.com] - Hayden pushing for Misano return Ninjette Newsbot Motorcycling News 0 August 20th, 2014 05:00 AM
[crash.net - MotoGP] - Marquez: I'm pushing like always Ninjette Newsbot Motorcycling News 0 November 8th, 2013 11:50 AM
pushing a bike... again alex.s General Motorcycling Discussion 12 October 9th, 2011 07:06 PM
[superbikeplanet.com] - Keep Pushing Man! Ninjette Newsbot Motorcycling News 0 July 21st, 2011 09:40 AM
