March 19th, 2012, 12:45 PM | #1 |
Join Date: Dec 2011 Motorcycle(s): 2004 Kawasaki Ninja ex250 Posts: 33
I need you guys to fix my bike! PLEASE! :)
Hey Guys!
I have a 2004 Ninja that has been sitting all winter. I recently purchased some carbs from a running bike and put them on mine. My diaphragms were shot from my carbs. I put the bike all back together and charged the battery. I went to start the bike and it will run, but only with choke on. I let it warm up for a while and tried taking it off choke. As soon as I started to move choke, the rpms dropped and the bike died. It did this repeatedly. It has all new fluids and grade high octane gas, it has been sitting, but sitting inside and smelled fine. Any references or suggestion would be fantastic! Thanks Emily |
March 19th, 2012, 12:54 PM | #2 |
What are the idle mix screws set at?
If you crank up the idle speed adjuster, will it die still? or will it sorta idle? Did you check the new carbs to see if the pilot jets and idle circuits are clean? |
March 19th, 2012, 01:02 PM | #3 | |
I adjusted the idler and it still died. I didn't really want to mess with too much and not get it back together. I checked the diaphragms and switch out the needles and thats it. |
March 19th, 2012, 01:31 PM | #4 |
Are the caps on top of the idle mix screws still or have they been taken off?
If they're off, screw the idle mix screws in just until they stop turning. Then count in 1/2 turn increments, and back them out 2.5 turns. That will get the screws roughly where they should be. Will it keep running if you hold the throttle? |
March 19th, 2012, 02:07 PM | #5 |
Join Date: Aug 2011 Motorcycle(s): 2004 Ninja 250R Posts: 46
Sounds like they need a good cleaning.
March 19th, 2012, 02:23 PM | #6 | |
I tried turning the throttle while turning off choked and the bike died. I wish I was a little more educated with bike maintenance and knew what I was doing. At this point I am mainly reading and trying to apply it! |
March 19th, 2012, 02:55 PM | #7 |
That's a good thing.
Have you read through faq.ninja250.org ? that's a great place to start off. Lots of good information |
March 19th, 2012, 03:03 PM | #8 | |
March 19th, 2012, 03:09 PM | #9 |
http://faq.ninja250.org/wiki/How_do_...ork_on_them%3F
I would pull the carbs and try cleaning the pilot jets and idle circuits with carb cleaner and compressed air. Do you have the ability to take it for a ride to warm it up once you start it? If it idles when hot but not when cold, that means that it's lean when idling. First step if you can get it warmed up is adjust the idle mix. If that doesn't work, clean the carbs and set the mix screws at 2.5 turns. If the EPA plugs are still over the mix screws, remove them when you clean the carbs. |
March 19th, 2012, 03:24 PM | #10 | |
Join Date: Dec 2011 Motorcycle(s): 2010 Ninja 250r (RIP) Posts: 258
Edit: Since you don't have the CA bike, yours would be exactly the same minus the t-fitting going to the emissions. Here is the link to all the pic goodness http://faq.ninja250.org/wiki/Carburetor_photos |
March 19th, 2012, 03:39 PM | #11 |
check your idle speed. look at the adjuster, its a cable that attaches to a screw that limits how far closed the throttle will get. adjust the screw until you can see that it is physically pushing on the cable wheel thing
March 19th, 2012, 05:41 PM | #12 | |
March 19th, 2012, 08:32 PM | #13 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
Adjust it more. Really, it likely could be that simple.
A very common mistake people make is setting stuff somewhere when it's not properly warmed up (several miles of riding.) Do what you did today again tomorrow, but when the bike is warmed up nicely (at least a few minutes, but don't let the thermometer go past half way) reduce the choke part way, so that the rpms drop a little, but the bike stays running. Make a mental note of where this point is. Turn the idle adjustment screw clockwise. Does doing so raise the RPM? If not, keep turning until it does. Understand that the adjuster just sets the minimum throttle position--it keeps the throttle from returning completely to 0 when you release it, since that would stall out the bike. So it holds the throttle at 1 or 2% open instead of letting it snap all the way back... Unless it's in totally the wrong position (which is possible if it was set by someone who didn't know what they were doing). When twisting the adjuster makes the revs increase by 2,000 or so, THEN you will be able to back off the choke a little bit more, and the revs will drop again. Keep increasing the idle adjuster and decreasing the choke a tiny bit each at a time until you can back off the choke all the way. That will likely solve your problems. Even if it doesn't, it's definitely what you should try before you start taking apart the carbs again and messing with the pilot jets and stuff... Glad to hear you got some carb diaphragms, btw.
"What a sweetheart."- ninja_sleeper to me |
March 19th, 2012, 08:35 PM | #14 | |
Milkshake Drinker
What sort of airbox/air filters are you running? The type as well as condition can have a huge effect on idle problems.
March 20th, 2012, 05:35 AM | #15 | |
I'm glad I got some carbs as well! Just have to get everything running and I'll be a lot more happy!! The airbox is the stock one that came with the bike. I curse that thing! |
March 20th, 2012, 06:58 AM | #16 |
Well he won't even start today....
March 20th, 2012, 07:10 AM | #17 |
for reference: http://faq.ninja250.org/wiki/What_is..._at_startup%3F
March 20th, 2012, 07:34 AM | #18 |
Well I got it to start and I was able to back the choke off a fair amount but not all the way. I got it to idle around 2000 - 3000 rpms. I tried to keep backing off the choke and turn the adjuster clockwise but it would not work either. I tried holding the throttle open and slowly backing off the choke but that didn't work either.
So I'm letting the bike cool and then I'm going to take the carbs off and try adjusting the mix screws. Thanks everyone for your help! I wouldn't have known where to start without you guys! |
March 20th, 2012, 07:41 AM | #19 | |
March 21st, 2012, 07:33 AM | #20 | |
1/2 + 1/2 + 1/2 = 2.5 or 1/2 + 1/2 + 1/2 + 1/2 + 1/2= 2.5 Also is there a way to do this on the bike without taking the carbs off!? This is my first bike ( obviously) so just asking obvious questions so I'll know for next time! |
March 21st, 2012, 07:37 AM | #21 | |
Join Date: Oct 2011 Motorcycle(s): 250 Ninja - Soon Posts: 96
this
March 21st, 2012, 07:52 AM | #22 |
March 21st, 2012, 07:53 AM | #23 |
There is never a wrong question.....
March 21st, 2012, 07:59 AM | #24 |
March 21st, 2012, 10:24 AM | #25 | |
[RideApart] - How To: Fix 5 Common Bike Issues | Ninjette Newsbot | Motorcycling News | 0 | July 21st, 2014 10:20 AM |
I can't fix this bike... Help | Jeeves | 1986 - 2007 Ninja 250R Tech Talk | 52 | June 20th, 2012 10:47 AM |
Help me fix my recovered stolen bike | kobachi | 2008 - 2012 Ninja 250R Tech Talk | 1 | July 11th, 2010 08:39 PM |
How to fix your bike | jorgecornet | Videos | 2 | October 17th, 2009 12:46 AM |
Fix damaged fairings + make your bike look cool! | subiegy2010 | General Motorcycling Discussion | 10 | September 28th, 2009 08:42 PM |
