Old August 10th, 2013, 05:57 AM   #1
deanomyte
Motorcycle(s): 99 honda rebel/ 04 ninjette
Oil level question
I changed the oil and filter. I made sure there was an appropriate amount of oil. I started the bike to check the idle, everything was fine. Now after not starting the bike for 2 months the oil level in the sight glass is reading low. Is this normal for bikes that sit? Or does placing a new oil filter affect the oil level by almost half the site glass?
deanomyte is offline   Reply With Quote
Old August 10th, 2013, 07:06 AM   #2
Aodrn
It's a long boring story
Aodrn's Avatar
Motorcycle(s): 2012 Ninja 250
I fill mine to the too of the glass. I idle it and then shut it down. Usually it is below the glass after that. Then I fill it to halfway between the lines on the glass. Sitting shouldn't make you lose oil.
Aodrn is offline   Reply With Quote
Old August 10th, 2013, 08:07 AM   #3
deanomyte
thanks for the help. just doing last minute checks before her first test drive!!
Old August 10th, 2013, 08:15 AM   #4
BlueRaven
BlueRaven's Avatar
Motorcycle(s): '09 Ninja 250 Black
When doing an oil change you put in your oil run the bike a few minutes check the level again you usually end up adding more. If you didn't do this last step probably explains why it seems low.
I'm not small, I'm fun sized
BlueRaven is offline   Reply With Quote
oil level RogerPapaMike 1986 - 2007 Ninja 250R Tech Talk 1 May 4th, 2014 02:54 PM
Oil Level tnr4 2013 - 2017 Ninja 300 Tech Talk 26 June 14th, 2013 10:33 AM
oil level always goes up .... tac12345 2008 - 2012 Ninja 250R Tech Talk 6 July 5th, 2010 06:02 PM
Noob Question - Oil Level carpediem General Motorcycling Discussion 7 April 27th, 2010 06:46 AM
