July 1st, 2015, 12:51 PM | #1 |
[American Motorcyclist Association] - Beta introduces 2016 off-road and dual sport mo
The following is an industry press release...
Beta is proud to announce their 2016 Xtrainer, RR, and RS models. Xtrainer 300: The Xtrainer returns with one large update, Beta will build more! This popular model's sales far exceeded production for 2015 and the Beta factory has stepped up production for 2016 to help fill the demand. This entry-level 300 cc off road machine brings fun back into the riding dictionary with it's "no-hit" yet powerful engine, oil injection, electric start, and a low seat height. Xtrainers will be available at Beta dealerships beginning in August at a suggested price of $7299.00. RR 2 Stroke: The big news for the 2016 RR Enduro 2 stroke models is the introduction of Beta's electronic oil injection system on both the 250 and 300 RR models. This system was introduced in 2015 on the Xtrainer model and has proven to be a huge success among Beta owners. This new feature ensures a perfect fuel-oil mix under any conditions and engine speed while saving riders from having to pre-mix. This new system also reduces 50% of the smoke from the exhaust compared to a traditional pre-mixed two stroke as the system is managed by an ECU with integrated mix and engine control which is able to measure the oil based on the engine's revs and engine load measured by the TPS (Throttle Position System). Oil Injection for the 2016 RR models Other 2 stroke RR updates include: The main frame has a stronger top shock mount to improve strength of the frame while also improving the feel of the chassis under the most demanding situations. The air filter box has been improved in terms of its water drainage. Also new are the air box cover fasteners that provide a more secure and dependable system. The front fork has been improved by increasing the size of the cartridge bleed hole to allow better oil flow during bottoming. Other changes include a longer spring guide to provide smoother action and lastly a more durable top-out spring has been installed. The odometer instrumentation is updated and integrates the lights indicating low oil level and separate oil injection system diagnostics. Grips with the Beta logo embossed in. The graphics retain the classic and distinctive Beta colors characterizing the Italian heritage. Even more stunning are the front fork tubes now with gold anodizing to match the rear shock reservoir. 2 Stroke RR models will be available at dealerships in August Suggested RR 2 stroke prices are: 250 RR $8299.00 300 RR $8299.00 RR 4 Stroke: The main innovation of the 2016 4 stroke RR Enduro range is the introduction of the electronic fuel injection system on all 4 stroke models. Fuel injection was already introduced on the 2015 350 RR model and has proved to be much more efficient than a carburetor, thanks to its great reliability and simple engine management, its extraordinary fuel delivery has received positive feedback from casual riders and racers alike. Beta's engineers have worked directly with Synerject to provide an EFI system that has proven to be tried and true. With its 42mm-diameter throttle body, the system ensures precise control of the fuel delivery under any condition, the air-fuel mixture is optimized at any altitude thanks to temperature and pressure gauges. Riders of all levels will enjoy spontaneous and linear engine response, thanks to the adoption of a stepper motor mounted on the throttle body, a precise minimum engine speed is guaranteed and engine braking is significantly reduced. This insures a smooth and predictable power delivery that is synonymous with Beta. EFI on all 2016 RR and RS 4 strokes Many other new features have also been added to the 4 stroke engines, with the aim of further improving power delivery and exploiting the engine's full power. The new intake ports on the 430 and 480 models have optimized flow for improved torque and power. The exhaust cam of the 480 has a new profile that provides a more linear power delivery. The rev limiter of the 350 has been brought up to 13,000 rpm (as opposed to the previous 12,500 rpm) for greater performance and provide more over-rev. The piston of the 350 and 390 models have new DLC-treated oil rings to reduce friction and oil consumption. The oil pressure valve has a new spring that offers greater stability at high temperatures, reducing the pressure variations in the system. The shift detent lever has a new aluminum roller that reduces the friction during gear changes and reduces wear on the gear starwheel which improves shifting action. The new tri-phase 18 pole electric ignition supplies power of 200 watts ensuring quicker battery charging. New diodes also reduce voltage losses further improving the charging system. New thermostat housing with four screws to improve durability. Many of the engine's screws are now in 7075 aluminum rather than steel for a greater weight savings. Many other new features have been introduced to further enhance handling as well as ease of maintenance. The skid plate is now made of plastic similar to the 2 stroke models. Made from the latest-generation polyamide that combines great impact resistance with extreme lightness, as well as offering greater protection against mud that can get in between the engine and the plate. The frame derives directly from the 2015 Racing model, the two main connection tubes to the steering head increased and created with a rectangular section in a special 41xx steel. This improved frame is a direct result of comprehensive analysis and research and has allowed for the rigidity of the various axes to be optimized for greater stability and riding precision. The new handlebar is lower providing improved weight transfer on corner entry and thus offering maximum control. The air filter box has been improved in terms of its water drainage. Also new are the air box cover fasteners that provide a more secure and dependable system. The front fork has been improved by increasing the size of the cartridge bleed hole to allow better oil flow during bottoming. Other changes include a longer spring guide to provide smoother action and lastly a more durable top-out spring has been installed. The odometer instrumentation has been updated and integrates lights indicating low fuel level and electronic fuel injection system diagnostics. The fuel tank is now translucent (from the 2015 Race Editions) allowing for a clear view of the fuel level in any situation. Grips with the Beta logo embossed in. The graphics retain the classic and distinctive Beta colors characterizing the Italian heritage. Even more stunning are the front fork tubes now with gold anodizing to match the rear shock reservoir. 4 stroke RR models will be available at dealerships in October Suggested RR 4 stroke prices are: 350 RR $9399.00 390 RR $9399.00 430 RR $9399.00 480 RR $9499.00 RS Dual Sport Like the RR models, the RS Dual Sport range also benefits from the introduction of the electronic fuel injection system. Many other new features have also been added to the 4 stroke engines, with the aim of further improving power delivery and exploiting the engine's full power. The new intake ports on the 430 and 500 models have optimized flow for improved torque and power. The exhaust cam of the 500 has a new profile that provides a more linear power delivery. The oil pressure valve has a new spring that offers greater stability at high temperatures, reducing the pressure variations in the system. The shift detent lever has a new aluminum roller that reduces the friction during gear changes and reduces wear on the gear starwheel which improves shifting action. The new tri-phase 18 pole electric ignition supplies power of 200 watts ensuring quicker battery charging. New diodes also reduce voltage losses further improving the charging system. Larger battery is fitted to improve starting while engine is hot. New thermostat housing with four screws to improve durability. Many of the engine's screws are now in 7075 aluminum rather than steel for a greater weight savings. New cylinder head ports improve power delivery Many other new features have been introduced to further enhance handling as well as ease of maintenance. The skid plate is now made of plastic similar to the 2 stroke models. Made from the latest-generation polyamide that combines great impact resistance with extreme lightness, as well as offering greater protection against mud that can get in between the engine and the plate. The frame derives directly from the 2015 Racing model, the two main connection tubes to the steering head increased and created with a rectangular section in a special 41xx steel. This improved frame is a direct result of comprehensive analysis and research and has allowed for the rigidity of the various axes to be optimized for greater stability and riding precision. The new handlebar is lower providing improved weight transfer on corner entry and thus offering maximum control. The air filter box has been improved in terms of its water drainage. Also new are the air box cover fasteners that provide a more secure and dependable system. The front fork has been improved by increasing the size of the cartridge bleed hole to allow better oil flow during bottoming. Other changes include a longer spring guide to provide smoother action and lastly a more durable top-out spring has been installed. Instrumentation has been updated indicating low fuel level and electronic fuel injection system diagnostics. Special Dual Sport soft seat foam for a more comfortable ride. Handguards are now standard equipment. New front brake hose that allows better viewing of the Voyager GPS unit. The fuel tank is now translucent (from the 2015 Race Editions) allowing for a clear view of the fuel level in any situation. Grips with the Beta logo embossed in. The graphics retain the classic and distinctive Beta colors characterizing the Italian heritage. Even more stunning are the front fork tubes now with gold anodizing to match the rear shock reservoir. RS Dual Sport models will be available at dealerships in November Suggested RS Dual Sport prices are: 430 RS $9699.00 500 RS $9799.00 Click here for full story...
[American Motorcyclist Association] - Yamaha introduces 2016 FZ-07 and FZ-09 | Ninjette Newsbot | Motorcycling News | 0 | June 4th, 2015 11:30 AM |
[American Motorcyclist Association] - Yamaha introduces all-new 2016 YZ250X two-strok | Ninjette Newsbot | Motorcycling News | 0 | June 4th, 2015 11:10 AM |
[American Motorcyclist Association] - Beta AMA National Dual Sport Series, Yamaha Sup | Ninjette Newsbot | Motorcycling News | 0 | February 11th, 2015 02:10 PM |
[American Motorcyclist Association] - AMA welcomes Beta USA as title sponsor for Beta | Ninjette Newsbot | Motorcycling News | 0 | January 16th, 2015 06:11 AM |
[American Motorcyclist Association] - Dual sport models among highlights in 2015 Beta | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2014 07:20 AM |
