Old April 21st, 2009, 09:41 AM   #1
Apex
Livin' the Minimoto Life
Apex's Avatar
2008 front forks
1. Can these be swapped into the '07 and earlier models
2. If so, is there any benefit to the swap?
I found a set for dirt cheap. I was wanting to jump on them if they would improve the ride of the bike for street/track use.
I have heard of people saying the J shock swap is good. I found one of those, but I am not going to do anything with it until the front end is improved. If the forks are better on the '08 model, then I'll get them.
Old April 21st, 2009, 10:39 AM   #2
sometimesido
sometimesido's Avatar
Motorcycle(s): 2006 250R
hm, if the forks work for earlier models and use J shock in the back, that'd be nice!
haven't heard any body trying them.
if the price is good, buy it and try it?
if it doesn't fit, sell it for more than you paid for.
my flickr™
sometimesido is offline   Reply With Quote
Old April 21st, 2009, 12:53 PM   #3
Apex
Apex's Avatar
I figured front forks would mean that I could piece together a 17" front wheel assembly, then move the rear to 17" and run nice and sticky tires.
Old April 21st, 2009, 01:15 PM   #4
sometimesido
but it cost more
my flickr™
Old May 13th, 2009, 08:00 AM   #5
jonb08
jonb08's Avatar
Motorcycle(s): 2007 EX250
Soooooo......????
jonb08 is offline   Reply With Quote
Old May 13th, 2009, 08:45 AM   #6
Snake
Snake's Avatar
When you find out let us know. I would like to do the same.
Old May 13th, 2009, 02:41 PM   #7
Apex
Apex's Avatar
I did see some on ebay. I'm saving up a little here and there before I commit to purchasing them. I'd love to find a 250R around here to take demensions on to make sure. It is hard to get technical drawings of parts (like the ones to MAKE the items). So I'll have to measure them myself.
Old May 13th, 2009, 02:43 PM   #8
just go to a dealer and start taking measurements. tell them you're researching your next bike purchase.... they'll leave you alone.
Old May 13th, 2009, 02:45 PM   #9
Snake
Snake's Avatar
^^^^not a bad idea.^^^^^^^^^^
Old May 13th, 2009, 02:46 PM   #10
Apex
Apex's Avatar
I have NEVER seen a 250 on the showroom floor there. They sell out way too quickly.
Old May 13th, 2009, 02:48 PM   #11
Snake
Snake's Avatar
There should be some at the South Central Rally. Bring a tape measure.
Old May 13th, 2009, 02:50 PM   #12
hell... take some calipers... tell them you're a very anal owner!
Old May 13th, 2009, 03:30 PM   #13
speedgsx98
Motorcycle(s): 250 ninja 2002, 2008 ZX10-R
i believe the new 250r's are 37mm.
having trouble finding specs on the 88-07 version though
speedgsx98 is offline   Reply With Quote
Old May 13th, 2009, 03:50 PM   #14
I believe the pregen forks are 36mm.
Old May 13th, 2009, 04:12 PM   #15
Apex
Apex's Avatar
Well I'd also measure the triple tree to see if that is an exact bolt up or not. It sure beats machining the stock triple tree to accept the 37's.
That would be the easiest swap.
Old May 13th, 2009, 10:26 PM   #16
Quiks66
Quiks66's Avatar
Motorcycle(s): '07 Ninja 250, '87 FZ600
I've looked into swapping the new forks onto an older model 250 and the costs generally outweigh the benefits, especially for a street bike. You'll have better forks out of the box (stiffer, static rate IIRC) and a 17" rim up front, but you'll need the entire front end to do the swap. That means fork tubes, upper and lower triple clamps, axel/spacers, rim, fender and so on. Not to say that it can't be done, but it's not the way I would go unless I wrecked my front end and got a deal on a 08+ complete front end.
I still envy the tire choices for the 17"ers though...
Quiks66 is offline   Reply With Quote
Old May 13th, 2009, 10:29 PM   #17
would you happen to know if the triple clamp would be a direct swap?
Old May 14th, 2009, 12:02 AM   #18
Quiks66
Quiks66's Avatar
Don't know for sure but I'd say probably not. Old model has 36mm forks and new model has 37mm so you'd have to shim them at the very least. Not something I'd choose to do on such a vital part of the bike!
Old May 14th, 2009, 12:10 AM   #19
I meant a direct swap of the new gen triple clamp/steering stem to the pregen frame.
Old May 17th, 2009, 05:30 PM   #20
Quiks66
Quiks66's Avatar
It would be close, but might need different bearings/spacers to make it work. I'll do some looking around and let you know if I find anything.
Old June 5th, 2009, 05:56 PM   #21
ROADandTRACK
R&T Suspension
ROADandTRACK's Avatar
New gen/old gen same bearings.
Direct swap, but you need everything from the new gen. Forks, wheel, axle etc.
You should also do the rear wheel swap, all you have to do for that is change the offset on the brake stay arm and mill the caliper hanger 13mm if I remember the spec right.
The rear is EASY, it took about an hour. But you need to cut and weld the brake stay.
ROADandTRACK is offline   Reply With Quote
