July 20th, 2009, 05:07 AM | #1 |
Join Date: Dec 2008 Motorcycle(s): 09 ninja 250 Posts: 42
New Kfactory front preload adjuster
Hey was up guys just wanted to get everyone's opinion on this new producthttp://www.k-factory.com/eng/ONLINE-...cap_blue_m.jpg is it worth 120 bucks?
July 20th, 2009, 06:05 AM | #2 |
Front fork preload adjusters
Materials:Aluminum(Duralumin) Price:¥12,600(including tax) It enables to seal the holes which is as a result of change of handlebar and to adjust preload of front fork spring. It makes sturdy underside by using with PD Fork bulb and Front fork spring at the same time. ※It gives about 5mm preload when you install it. |
July 20th, 2009, 12:26 PM | #3 |
nice piece, but if you want 5mm of preload, why not put a 5mm PVC pipe spacer in your forks and save about $100?
I did this back in the days of dirt bikes. I would cut different lengths of PVC spacers made out of regular PVC pipe and "tuned" the front forks by trying different lengths and finding out which work the best for your application. Type of riding, rider weight and riding style all play into what is "right" for you. also, you can play with oil height in the tubes as well as oil weight to improve/"tune" the forks. |
July 20th, 2009, 07:20 PM | #4 |
Good point. And pvc in ninja isn't under save pounding forces as in dirtbike.
Posted via Mobile Device |
November 19th, 2009, 12:05 PM | #5 |
voda?
Join Date: Oct 2009 Motorcycle(s): .... & a Ninja 250 duh Posts: 65
I haven't installed them yet but here is how they look in pictures (please note there is a washed and e-ring, which press against the spring/spacer that are missing in the photos):
EDIT: I have the "missing" parts I just meant that I didn't take a picture of them that's all I did get sent everything. Last futzed with by Dmitriy; November 19th, 2009 at 01:13 PM. |
November 19th, 2009, 12:45 PM | #6 |
Join Date: Oct 2009 Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r Posts: 959
They look nice - are the missing parts being replaced? Keep us posted on install.
November 19th, 2009, 04:36 PM | #7 |
Dimitry, where did you get them?
November 19th, 2009, 05:42 PM | #8 |
voda?
I ordered them from K-Factory in Japan, they do respond to emails you know
Email them telling what part you want (make sure to specify color) give them your address and ask for bank transfer info etc.... Wire some money from your bank (include 4,000 yen extra for fee on their end as they want you to pay those too) and you are good to go. If these work well, I think there are 2 ways about it really. 1 is to order a good size shipment from them all at the same time to save on wire fee's and shipping costs or measure up a set and get a machine shop here in the good o'e US of A to manufacture them there by ripping off the little guy in Japan. Both have + / - |
November 19th, 2009, 07:06 PM | #9 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
^ given the actual market both approaches aren't really feasible.
Sportisimoto USA is born. |
DIY preload adjuster | alex.s | General Motorcycling Discussion | 69 | May 14th, 2020 05:57 AM |
DIY: spring and preload adjuster install (tim style) | Timr | 2008 - 2012 Ninja 250R Tech Talk | 3 | October 7th, 2012 06:10 AM |
2012 SlingShotRacing Preload Adjuster Group Buy | DailyRidden250R | Motorcycle-related | 133 | July 18th, 2012 05:52 AM |
2008+ SSR Preload Adjuster and Driven Clip for Sale! | DailyRidden250R | Motorcycle-related | 8 | June 26th, 2012 06:27 AM |
Q: How would u install Preload adjuster without front stand? | DailyRidden250R | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 16th, 2012 04:14 PM |
