March 3rd, 2014, 01:08 PM | #1 |
Clutch lever light activator broke? Replacements?
When installing my new clutch lever I was rushing and broke off the little "nipple" that gets pushed in when you squeeze the clutch lever, any idea on where I can get a new one?
March 3rd, 2014, 01:49 PM | #2 |
Certified looney toon
MOTM Jul '13, Jul '14
Do you mean this thing?
If so, that's the Switch, it's part number 27010-1094, and they can be picked up at places like Bike Bandit, Kawasaki Parts House, even @PartsNinja may have one.
March 3rd, 2014, 05:14 PM | #3 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
You don't really even need it though. I broke mine off as well when I changed out the lever. IIRC it's used so you can't start the engine in gear unless clutch is pulled. So no switch means you just start engine in neutral.
March 3rd, 2014, 05:21 PM | #4 | |
Actually the other way around,
March 3rd, 2014, 06:53 PM | #5 |
I appreciate the help! Ordered I now know to make sure thats pushed in before I put a lever on:P
March 3rd, 2014, 07:58 PM | #6 |
Join Date: Aug 2012 Motorcycle(s): 2013 White 300 Posts: 221
Speaking of this little guy, is it safe to clip these down a little? My aftermarket levers don't let it depress fully, so I can only start it in neutral. Trimming it a little won't make it think the clutch is always pulled in will it?
March 5th, 2014, 05:34 AM | #7 | |
Ninja Parts Master
Join Date: Aug 2013 Motorcycle(s): 2011 Ducati Streetfighter 1098, 2014 Honda CB1100 Cafe, 2007 SV1000S, Quite a few 2008-2012 Ninja 250s Posts: 366
I have a bag full of these if you still need one. $10 shipped or I can throw one into the box if you purchase any item that is more expensive.
Add me on Instagram: @d_jalb Or follow me on eBay: PartsNinja |
March 7th, 2014, 03:26 AM | #8 |
I needed a couple things cost me alot more than buying from you, I shoulda pm'd ya
New Problem - Broke heads off two clutch spring bolts | indr | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 30th, 2013 11:32 AM |
WTB: Clutch lever, handle bar end, dummy cap, and clutch lever holder. 09 250r | SwagenGTI | Items Wanted | 5 | March 4th, 2013 12:20 PM |
Clutch Lever (Broke Something) | Outlander Systems | 2008 - 2012 Ninja 250R Tech Talk | 23 | June 15th, 2012 03:44 PM |
clutch cable broke | GreenNinja | Ride Reports | 10 | May 10th, 2012 05:48 PM |
Ebay lever broke my clutch lever mounting bolt! | pilotgeorge747 | 2008 - 2012 Ninja 250R Tech Talk | 8 | December 22nd, 2011 07:22 AM |
