Old October 1st, 2019, 11:51 AM   #41
Zolland
Motorcycle(s): 2005 Ninja 250R
@Triple Jim @DannoXYZ I think I have all of the grommets!
Also, just wanted to ask this real quick.
I lost a fair bit of oil. Is there any way to change this oil without taking off the valve cover? If not should I just change/top off this oil now so I don't have to take everything off for a third time soon?
I have everything off and access to the valve cover right now. I just want to see if I should go get oil before closing everything off tonight.
Zolland is offline   Reply With Quote
Old October 1st, 2019, 12:57 PM   #42
Changing the oil doesn't involve the valve cover.
https://faq.ninja250.org/wiki/Engine_Oil
Old October 1st, 2019, 01:58 PM   #43
Zolland
Is that the same oil that is in the top end with the valves? If so how does it get up there?
Old October 1st, 2019, 02:21 PM   #44
Yes, same oil. The engine's oil pump gets it there.
Old October 1st, 2019, 03:00 PM   #45
Zolland
Wow, had no idea! In my defense this is my first time working on a 4 stroke haha
Old October 1st, 2019, 03:39 PM   #46
Yes, 4-strokes are evil. I've had this most of my life.
Old October 1st, 2019, 03:54 PM   #47
59096
59096's Avatar
Motorcycle(s): GPX250 1989 model and 1990 model
Last time I adjusted my pregen valves I found that is was necessary to tighten the four bolts right the way down using the old gasket to stop minor oil leaks. But I am guessing that you might not have it seated correctly as it really shouldn’t leak much even if slightly loose
Perpetua Culpa Alterna Vagus
59096 is offline   Reply With Quote
Old October 2nd, 2019, 10:35 AM   #48
Zolland
@Triple Jim Wow that thing looks sweet! What is it?
@59096 haha yup, what I said below describes me making the same mistake
And to give everyone a final update, I'm pretty sure I've FINALLY finished the valve adjustment. The manual calls for something like 87in/lbs of torque, but the wiki says this can be achieved by hand tightening then one more 1/8th of a turn... this is SUPER wrong haha
I used my torque wrench and now everything is working, mind the other small issues I brought up earlier but I think those can use their own threads to keep things separate.
Thank you to everyone that helped me through this long process! I learned a lot from yall and I'm sure I'll keep learning more
Old October 2nd, 2019, 10:40 AM   #49
Thanks. It's a 1972 Kawasaki H2 (750)
Bike Hesitates to Start Without Throttle Input ninjayetti 2008 - 2012 Ninja 250R Tech Talk 60 March 26th, 2016 01:34 PM
Bike won't start, cleaned carbs, new gas, backfires whats next? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 7 July 26th, 2013 09:53 PM
Thinking of Upsizing... Input on naked bikes? dfox General Motorcycling Discussion 68 October 4th, 2012 02:38 PM
Is this symptomatic of dirty carbs? CmichRider 1986 - 2007 Ninja 250R Tech Talk 26 June 15th, 2012 11:34 AM
Dirty Carbs? forevertwowheels 2008 - 2012 Ninja 250R Tech Talk 2 April 19th, 2011 09:07 PM
