June 26th, 2013, 09:25 AM | #1 |
Join Date: Jan 2013 Motorcycle(s): 2009 Ninja 250R Posts: 206
Rear caliper allen key bolt stripped
I was trying to get the rear brake caliper off on my bike and now one of the allen key bolts has been rounded out. When I insert the allen key, it just slides around and doesn't grip.
What should I do? Thanks. |
June 26th, 2013, 09:30 AM | #2 | |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Bigger Allen key or comperable metric size or sae size Hammer based Impact tool Screw extractor Ex out Grind a slot into it and use a slotted screwdriver Grind head completely off and use vice grips on remainder Do Something with heat around the bolt? Drill out with slightly smaller drill but and retap threads Flat bed Tow to mechanic to have them do one of the above
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
June 26th, 2013, 09:31 AM | #3 |
Drill it head completely out or get yourself a bolt extractor, EZ-out or the like.
June 26th, 2013, 10:04 AM | #4 |
Take a Torx bit that is one size too big to fit in the hole. Then spend a lot of time hammering it in there. Don't pound too hard. But, you want to make sure that it's in all the way (or very close to the bottom of the hole). If you don't, you're going to end up with a bigger hole when you go to turn it. I've done this twice (both times on the same bolt as yours) and it has worked every time.
You just have to take your time and make sure that the head of the torx bit is in as far as it'll go. |
June 26th, 2013, 10:14 AM | #5 |
Does anyone have two spare rear caliper bolts for sale? I believe the part number is 120CA0816
It's the two bolts that hold the caliper in place, not the two pins that go through the brake pads. |
June 26th, 2013, 10:46 AM | #6 |
Cheaper to pick up matching metric bolts from Home Depot.
June 26th, 2013, 11:00 AM | #7 |
I prefer staying with OEM bolts, especially since these are for the caliper. If anyone has a spare set I don't mind paying for them and the shipping, which should only cost like a dollar or two.
June 26th, 2013, 11:07 AM | #8 |
A bolt is a bolt. For the most part.
June 26th, 2013, 12:22 PM | #9 |
Join Date: Oct 2012 Motorcycle(s): '04 R1 and '08 Ninja 250 Posts: 222
Mrcycles.Com has Them For $2.08 Each... Retail Is 2.98... Dealership Will Be Your Best Bet If You Insist On OEM.
Check out this Ninja 250 roadracing youth---> TheDraik77 <--- My son |
June 26th, 2013, 12:55 PM | #10 |
Home Depot has em for $.75
June 29th, 2013, 11:36 AM | #11 |
I bought a replacement bolt from Ace Hardware, but it's slightly thinner than the OEM bolt. When I screw it in it doesn't stop in the threads and ends up touching the rotor.
Is there anything I can do or am I just going to have to buy an OEM bolt? |
June 29th, 2013, 01:09 PM | #12 |
You bought an SAE bolt. Get a metric bolt instead.
If the bolt is still too long, cut it off with a hacksaw or cutting blade. |
June 29th, 2013, 01:30 PM | #13 |
I don't believe so. I took the OEM bolt into the store and an employee helped me find a match for it. The head on the bolt is the same (hex key) but the threaded part is skinnier than the OEM bolt so when I screw it into the caliper, it just keeps turning and doesn't stop like the OEM one.
June 29th, 2013, 01:37 PM | #14 |
It's not the same bolt. Was the bin labelled something like "M8x__" ?
Lowe's has a small selection of metric bolt. You're looking for a M8x36. The 36 is the length (in millimetres) of the bolt below the head. You should be able to get away with something as low as M8x34. But, it's better to get the next size up and cut off the excess. |
June 29th, 2013, 01:38 PM | #15 | |
Fast-Guy wannabe
MOTM - Jan '13
Don't trust a hardware store employee to fine you anything metric, they normally know less then you |
June 29th, 2013, 02:04 PM | #16 |
Yes, it was the metric container. I'm not saying it's the exact same bolt because obviously it's not if it's thinner. I'm saying that it is a metric bolt though and not SAE.
Should I try Home Depot or Lowes then? |
June 30th, 2013, 12:20 PM | #17 | |
I know lowes has a display the you can run the bolt into to make sure you get the right pitch and diameter, then it is just a matter of getting the right length.
June 30th, 2013, 12:32 PM | #18 |
I found the right one at Lowes. Thanks for the help.
Installed new front and rear tire and went for a ride and got caught in heavy rain/wind I rode like a grandma and didn't have any problems but it was definitely a scary twenty miles. |
badly stripped brake caliper screw | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 16 | February 10th, 2016 05:34 PM |
Allen bolt by oil filter | Tristan1504 | 1986 - 2007 Ninja 250R Tech Talk | 2 | June 30th, 2014 12:27 AM |
Stripped Allen Screw/Front fork change | ManOfGod | 1986 - 2007 Ninja 250R Tech Talk | 7 | April 30th, 2013 10:43 AM |
Stripped Allen Head | Scattcatt | 2008 - 2012 Ninja 250R Tech Talk | 39 | April 8th, 2012 01:33 PM |
Stripped Bolt head on oil filter | Liber | 2008 - 2012 Ninja 250R Tech Talk | 17 | July 17th, 2011 08:23 AM |
