Old January 17th, 2018, 11:13 AM   #1
94droptop
Motorcycle(s): 2006 ex250
Engine gaskets
Dose anyone have a link for gasket outlines? I could have sworn at one point in time I saw a link for it but cant find it now.
94droptop is offline   Reply With Quote
Old January 17th, 2018, 11:28 AM   #2
Which gaskets?
Old January 17th, 2018, 12:09 PM   #3
94droptop
case covers and the oil strainer. I can buy them and make outlines, but i was just trying to be cheap
Old January 17th, 2018, 12:11 PM   #4
When I want to make a gasket, I lay the material on the part and tap around it with a soft hammer gently. It leaves a print I can follow to cut it out. But maybe you already know that technique.
Old January 17th, 2018, 03:27 PM   #5
94droptop
I was going to use grease/or ink to do that but. I like your idea better. thank you.
Old January 17th, 2018, 03:50 PM   #6
You're welcome. It's the way my father taught me to do it when I was about eight or ten (late 60s) and he got a discarded lawnmower engine so we could take it apart and put it back together. Welcome to the board by the way, Cody.
Old January 17th, 2018, 04:06 PM   #7
94droptop
Thank you Hoping to get thing together for a track day this summer.
Old January 17th, 2018, 04:53 PM   #8
I just lay cover over gasket-material and trace outside with sharp Xacto knife. One-pass and it's 1/2-done.
Then I carefully do inside-cut while maintaining constant width. 2nd-pass and it's done.
Nice clean edges that doesn't protrude past edge of cases like a gang of beavers gnawed at it.
I've also tried computer-controlled vinyl-cutter, but that took longer to draw shape correctly than to just carve by hand.
Also considered laser-engraver, but again, takes a while to draw exact shape of gasket to guide laser. Faster to wield Xacto knife!
Old January 17th, 2018, 06:34 PM   #9
Ram Jet
Ram Jet's Avatar
If you have a computer printer sometimes you can lay the part on the platin glass and make a copy that you can then glue to the gasket material with a glue stick. A cork hole borer works well for punching screw and bolt holes.
Bill
Old January 18th, 2018, 11:24 AM   #10
94droptop
You sir are my hero. I would have never thought about that.
Old January 18th, 2018, 11:33 AM   #11
Bill
Would a copier work too?
Old January 18th, 2018, 12:58 PM   #12
Ram Jet
Ram Jet's Avatar
Sure. I would advise placing a piece of clothing or cloth over the object you're copying to block as much extraneous light from hitting the platen (spelled right this time) glass. If you can, turn off all the lights in the room also.
Bill
Old February 6th, 2018, 12:39 PM   #13
94droptop
Did the copy trick yesterday, and it worked great. Thanks again for the help.
what gaskets to change during engine tear down? ebrammer252 1986 - 2007 Ninja 250R Tech Talk 19 May 22nd, 2014 04:07 AM
Gaskets The_big_dill 1986 - 2007 Ninja 250R Tech Talk 10 November 6th, 2013 06:27 AM
Make your own gaskets cuong-nutz General Motorcycling Discussion 4 October 11th, 2013 03:09 PM
Petcock gaskets? MasterCylinder 1986 - 2007 Ninja 250R Tech Talk 15 September 12th, 2013 06:02 AM
Engine-to-Header gaskets (NewGen) USMCEvan 2008 - 2012 Ninja 250R Tech Talk 2 March 18th, 2012 09:45 PM
