Old January 26th, 2018, 01:27 PM   #1
metalmania
metalmania's Avatar
Motorcycle(s): a bunch
Question anyone up for local tutoring on carbs?
anyone well-versed in the carb (& local to Fairfield/Vacaville, CA 94533) have some time and up for local tutoring? I can pay for your time if reasonable.
I've taken care of some of the basic maintenance (eg: spark plugs, oil/filter, inline fuel filter, etc), by watching YT vids and reading docs/forums online. Lots of great info
I have an '03 250 and is my first bike with a carb. I thought it be a good idea to have someone school me on carbs; maybe at a minimum do a removal/cleaning/re-install/test?
I'm also up for me removing the carb and coming to you (within ~30 miles from 94533).
I have tools; I just need someone's experience and brain
Let me know time-availability and rate, if interested.
Thanks in advance.
~D
metalmania is offline   Reply With Quote
Old January 26th, 2018, 01:40 PM   #2
Hi, I'm just 15-minutes south of you and can help you with basic carb work.
What kind of issues are you having with carbs?
Cold start & choke problems?
Stumbling at partial-throttle?
Stumbling at full-throttle?
Old January 26th, 2018, 01:46 PM   #3
metalmania
metalmania's Avatar
replied to your PM
no issues with the bike; it runs pretty solidly.
my request is more for a preventative-/maintenance session, more so than a troubleshooting session.
Old January 26th, 2018, 02:02 PM   #4
Ok, we can do basic maintenance. Perhaps you can order a carb-rebuild kit first, and then we clean and install:
- carb-removal (should separate battery-box to make future-removal easier)
- carb-disassembly
- jets removal
- soaking/cleaning of carb pieces
- float-bowl seal replacement
- float-valve replacement
- float-height measuring & adjustment if neceesary
- vacuum-hose replacement
- carb re-install
I leave anything out?
Old January 26th, 2018, 02:14 PM   #5
metalmania
metalmania's Avatar
- carb-disassembly
- jets removal
- carb re-install
cool - sounds good
any recommendations on which rebuild kit to order and from where?
Old January 26th, 2018, 03:08 PM   #6
If things are working, no need to replace much more than rubber parts. Here's basic rebuild kit on ebay: https://www.ebay.com/itm/222262539152
Old January 26th, 2018, 03:28 PM   #7
Ram Jet
Ram Jet's Avatar
Thanks in advance.
~D
Dang, I'm retired and have a-lot of time. Too bad you aren't closer to Michigan. You could even afford my fee - $0.00.
Bill
Old January 26th, 2018, 03:49 PM   #8
metalmania
metalmania's Avatar
Bill
Thanks for the offer Bill; I appreciate it
Are you sure you don't live on Michigan Street in Fairfield, CA?
Old January 26th, 2018, 03:54 PM   #9
metalmania
metalmania's Avatar
Thanks. Just ordered a couple of Outlaw Racing OR2728 kits from Amazon. Should arrive by Mon 1/29.
Old January 26th, 2018, 04:42 PM   #10
Ram Jet
Ram Jet's Avatar
I tried to down load the URL for this You Tube how-to but couldn't. This is the best way I have found to remove the carbs;
In the You Tube search box type in "Simple Way to Remove the Carburetors on a Ninja 250 Pregen"
Bill
Old January 27th, 2018, 10:03 AM   #11
94droptop
Motorcycle(s): 2006 ex250
You should look up The Vintage Monkey in Sac. I know they are doing a class on carbs. Plus is a really cool place to visit
94droptop is offline   Reply With Quote
Old January 27th, 2018, 11:51 AM   #12
metalmania
metalmania's Avatar
Thumbs up
Thanks Cody. Looks like they don't have any future carb classes posted yet. I wonder how often they offer these classes. I'll keep checking their site. Thanks again.
Old January 27th, 2018, 11:52 AM   #13
94droptop
I believe they just had one. Must have just missed it.
Old January 27th, 2018, 11:52 AM   #14
metalmania
metalmania's Avatar
Thumbs up
Bill
Thanks Bill. I was able to watch the vid. Good stuff.
Old February 28th, 2018, 07:45 PM   #15
a2ninjadude
Motorcycle(s): 2004 Kawasaki Ninja EX250F
a better way to remove carbs
guys, check this one out. i just did it this way and it took all of 10 minutes flat.
https://youtu.be/s86bimD4ft0
a2ninjadude is offline   Reply With Quote
Old February 28th, 2018, 09:23 PM   #16
Ram Jet
Ram Jet's Avatar
Not me. When you make the cut there is no support for the rear of the air box.
A little help with my carbs? soonerbillz 1986 - 2007 Ninja 250R Tech Talk 3 August 28th, 2014 07:29 AM
My Local Track oblivion007 Videos 3 July 28th, 2013 01:43 PM
Local cruise. Sipper' Ride Reports 1 January 26th, 2013 12:56 PM
Saw this on my local CL cerberusrex25 General Motorcycling Discussion 27 January 6th, 2012 08:43 PM
local riders stroked59 General Motorcycling Discussion 4 December 30th, 2008 09:45 PM
