March 25th, 2018, 12:08 PM | #1 |
Strange turn-signal problem
So, been noticing that occasionally my turn signals just randomly stop working while riding. If I leave the switch on as though I am indicating a turn, most of the time the come back some time later all by themselves. Thinking this might be a flasher issue, and the fact that my rear left-turn indicator was hanging, I replaced the flasher with an LED flasher and replaced the indicators with LED indicators.
Now, the signals work about 90% of the time, but it is noticeable when I start the bike. If I turn off the bike and turn it back on, it seems to resolve itself. Would this be a symptom of a failing/latching turn switch, or something else? |
March 25th, 2018, 05:51 PM | #2 |
Measure voltages at connector right after handlebar switch. Match up states of wires with position of switch. If they don't match, jiggle the switch and see if signal changes. Sure sign you have switch that's on its way out. Sometimes can be revived with silicone spray to help it slide easier and free up the springs.
Last futzed with by DannoXYZ; March 25th, 2018 at 06:53 PM. |
March 25th, 2018, 07:46 PM | #3 |
Great idea! I will give that a shot.
March 28th, 2018, 04:34 AM | #4 |
^^while you're at it, do a once-over on all the electrical connectors on the turn signal system. Off the top of my head, there's connectors at the turn signals themselves, at the thermal flasher, and the switch on the handlebars.
Turn signal problem | ChickenRun | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 9th, 2013 05:44 PM |
Turn signal problem | kawasaki-guy2008 | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 4th, 2013 09:07 AM |
Turn signal problem | PistolPete93 | 2008 - 2012 Ninja 250R Tech Talk | 19 | July 17th, 2012 10:54 AM |
Turn Signal Problem | shawn57187 | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 17th, 2011 02:13 PM |
Turn signal problem!!! | danjaho | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 23rd, 2011 07:25 AM |
