Old May 17th, 2013, 03:14 PM   #1
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
Stumped
Two weeks ago I was riding around town for about an hour and a half. Bike was running perfectly normal but about a block away from the house the revs seemed to be hanging before slowly dropping back to normal idle then died as pulling into driveway. Seemed to be a sudden lean running condition.
Specs on bike: Area P full system, KN Pod filter, Sportisi Jet Kit. Pod filter was dirty as crap, pulled it off and cleaned it. Same rev hanging problem continued. Wasn't able to look further into the problem at time due to leaving for a business trip.
Today I was able to start looking further into the problem. Pulled carbs out, checked slides, needles, jets, and floats. No problem identified. Throttle cables properly adjusted. Put carbs back in but problem continues. Rev hang seems to start at about 4k.
I ride the bike on a near daily basis, was never stored or sat for an extended period of time. For the problem to arise suddenly it has me stumped.
Here is a quick Video
Last futzed with by LoD575; May 17th, 2013 at 04:56 PM.
LoD575 is offline   Reply With Quote
Old May 17th, 2013, 03:31 PM   #2
mgentz
Board Member
What jetting?
Old May 17th, 2013, 04:23 PM   #3
LoD575
LoD575's Avatar
Jetting specs: 105 DJ, 38 Pilot, Clip in 4th position on needle.
Old May 17th, 2013, 04:31 PM   #4
last valve check was...?
Old May 17th, 2013, 04:52 PM   #5
LoD575
LoD575's Avatar
Have not done a valve check. Bike is a 2012 with 2,952.6 miles.
I did the full exhaust, pod filter, Kleen air delete in July 2012.
Old May 17th, 2013, 05:31 PM   #6
what was the purpose for the pod filters? are you trying to get power? you can get more power with the airbox than you can with pod filters.
your valve train sounds horrible btw, especially for only 3k miles. which makes me think the jetting has been extremely lean, overheating the exhaust valves. or the guy you bought it from was a scam artist and the bike has more like 15k miles on it.
do a valve adjustment and check your cam chain to make sure its in spec. put the airbox back in. rejet.
Old May 19th, 2013, 09:53 AM   #7
LoD575
LoD575's Avatar
I went the pod filter route for power. I was planning on putting the airbox back in along with re-jetting next month after moving, going from 4,200 ft elevation to 200 ft.
Strange that you mention how the valve train sounds. I have been the only owner of the bike and the valve train has sounded like that since purchase.
After the move I will tear it down for a valve and cam chain check.
Thanks for the input alex.s
With the bike naked I also discovered the right fork seal to be leaking.
No spark.. stumped MaliZ 1986 - 2007 Ninja 250R Tech Talk 24 November 27th, 2012 05:58 PM
